engine taredown results,REBUILD.
#815088
09/26/10 05:44 PM
09/26/10 05:44 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
she just needs barings and head gaskets and i will get head studs as i think it is time for the bolts to be replaced. i will give the parts a good cleaning and start to reassemble for next yr.the head bolts were not as tight as thay should be but i have not had to retorque them in the past and have checked them.
Re: engine taredown results,
[Re: blownzoom440]
#815093
09/26/10 09:07 PM
09/26/10 09:07 PM
Posts: 1,845 Tampa
DusterDave
Tampa
What happened to the head gasket? Got a pic of it?
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: DusterDave]
#815094
09/26/10 09:10 PM
09/26/10 09:10 PM
blownzoom440
ELYRIA,OH
it looks like the bolts were not tight enough.when i took it apart thay came loose easy accept the middle bolts.
[Re: blownzoom440]
#815097
09/26/10 09:48 PM
09/26/10 09:48 PM
Posts: 1,090 north cakalaky
instigator
north cakalaky
I aint never had that much intrusion of combustion gases onto the face of a copper gasket....like you were saying either not enough tension on the bolts or some serious detonation..though pistons all look fine, correct...with the amount of water getting into the cylinders also you must have had a sealing problem.....I always use permatex 300 slathered on all 4 surfaces and never a water, oil or cumbustion leak before. http://www.permatex.com/products/Automot...ket_Sealant.htm
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
[Re: blownzoom440]
#815099
09/26/10 10:36 PM
09/26/10 10:36 PM
instigator
north cakalaky
either advance or autozone carries it on the shelf.
[Re: moparmattkos]
#815101
09/26/10 11:04 PM
09/26/10 11:04 PM
blownzoom440
ELYRIA,OH
How much use is on this motor MS??
about 4 dyno pulls and 7 passes.i am sure the head bolts were loose from the start and i should have noticed it on the dyno.the head bolts[ARP] are older[10 yrs] with about 8 retorques.
[Re: blownzoom440]
#815105
09/28/10 09:21 PM
09/28/10 09:21 PM
Posts: 871 WA 98043
thecarfarmer
WA 98043
I'd be lookin' at why those bearings don't show a little more even wear across the surface. Crank flexing, block flexing, caps walking, tapered or hourglass journals... gotta' be a reason. I'd mic that crank all over all its journals, maybe set the block up for a light swish with the line hone to see if the main line is still straight.
-Bill
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
[Re: thecarfarmer]
#815106
09/28/10 09:43 PM
09/28/10 09:43 PM
blownzoom440
ELYRIA,OH
-Bill
i was just looking at the clevite site trying to figure out what is going on.i did have low oil psi.[40psi all rpm]
