Page 1 of 3 1 2 3
engine taredown results,REBUILD. #815088
09/26/10 05:44 PM
09/26/10 05:44 PM
ELYRIA,OH
blownzoom440 Offline OP
ELYRIA,OH
she just needs barings and head gaskets and i will get head studs as i think it is time for the bolts to be replaced. i will give the parts a good cleaning and start to reassemble for next yr.the head bolts were not as tight as thay should be but i have not had to retorque them in the past and have checked them.
Re: engine taredown results, [Re: blownzoom440] #815089
09/26/10 06:09 PM
09/26/10 06:09 PM
ELYRIA,OH
ELYRIA,OH
2
Re: engine taredown results, [Re: blownzoom440] #815090
09/26/10 06:10 PM
09/26/10 06:10 PM
ELYRIA,OH
ELYRIA,OH
3
Re: engine taredown results, [Re: blownzoom440] #815091
09/26/10 06:12 PM
09/26/10 06:12 PM
ELYRIA,OH
ELYRIA,OH
Re: engine taredown results, [Re: blownzoom440] #815092
09/26/10 06:13 PM
09/26/10 06:13 PM
ELYRIA,OH
ELYRIA,OH
Re: engine taredown results, [Re: blownzoom440] #815093
09/26/10 09:07 PM
09/26/10 09:07 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
What happened to the head gasket? Got a pic of it?
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: engine taredown results, [Re: DusterDave] #815094
09/26/10 09:10 PM
09/26/10 09:10 PM
ELYRIA,OH
ELYRIA,OH
it looks like the bolts were not tight enough.when i took it apart thay came loose easy accept the middle bolts.
Re: engine taredown results, [Re: blownzoom440] #815095
09/26/10 09:12 PM
09/26/10 09:12 PM
ELYRIA,OH
ELYRIA,OH
here is the gasket.
Re: engine taredown results, [Re: blownzoom440] #815096
09/26/10 09:13 PM
09/26/10 09:13 PM
ELYRIA,OH
ELYRIA,OH
other side.
Re: engine taredown results, [Re: blownzoom440] #815097
09/26/10 09:48 PM
09/26/10 09:48 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
I aint never had that much intrusion of combustion gases onto the face of a copper gasket....like you were saying either not enough tension on the bolts or some serious detonation..though pistons all look fine, correct...with the amount of water getting into the cylinders also you must have had a sealing problem.....I always use permatex 300 slathered on all 4 surfaces and never a water, oil or cumbustion leak before.
http://www.permatex.com/products/Automot...ket_Sealant.htm
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: engine taredown results, [Re: blownzoom440] #815098
09/26/10 10:13 PM
09/26/10 10:13 PM
ELYRIA,OH
ELYRIA,OH
thanks for the link she was leaking bad forsure.
i have to clean the cylinder wall before i pull the pistons to try to save the rings that are new.on some pistons all in the quench area on the carbon buildup only you could see signs of detonation on 3 of the pistons.looks like i got lucky.
Re: engine taredown results, [Re: blownzoom440] #815099
09/26/10 10:36 PM
09/26/10 10:36 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
either advance or autozone carries it on the shelf.
65 Barracuda
Re: engine taredown results, [Re: instigator] #815100
09/26/10 10:54 PM
09/26/10 10:54 PM
Illinois
moparmattkos Offline
mopar addict
mopar addict
Illinois
How much use is on this motor MS??
www.sikosracing.net Heads up Drag racing
Re: engine taredown results, [Re: moparmattkos] #815101
09/26/10 11:04 PM
09/26/10 11:04 PM
ELYRIA,OH
ELYRIA,OH
about 4 dyno pulls and 7 passes.i am sure the head bolts were loose from the start and i should have noticed it on the dyno.the head bolts[ARP] are older[10 yrs] with about 8 retorques.
Re: engine taredown results, [Re: blownzoom440] #815102
09/27/10 09:53 AM
09/27/10 09:53 AM
IN
BIG BEAR Offline
BIG BEAR  Offline
IN
Sorry to hear about the problems Metal Storm, hopefully they get resolved soon so you can get that thing running again
Re: engine taredown results, [Re: blownzoom440] #815103
09/27/10 07:38 PM
09/27/10 07:38 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Just reinstall those old head bolts with lockwashers on them, and you'll be good for another 10 years.
Re: engine taredown results, [Re: DusterDave] #815104
09/27/10 08:13 PM
09/27/10 08:13 PM
ELYRIA,OH
ELYRIA,OH
allready making up the parts list.
ARP 145-4006
Re: engine taredown results, [Re: blownzoom440] #815105
09/28/10 09:21 PM
09/28/10 09:21 PM
WA 98043
thecarfarmer Offline
WA 98043
I'd be lookin' at why those bearings don't show a little more even wear across the surface. Crank flexing, block flexing, caps walking, tapered or hourglass journals... gotta' be a reason. I'd mic that crank all over all its journals, maybe set the block up for a light swish with the line hone to see if the main line is still straight.
-Bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: engine taredown results, [Re: thecarfarmer] #815106
09/28/10 09:43 PM
09/28/10 09:43 PM
ELYRIA,OH
ELYRIA,OH
-Bill
i was just looking at the clevite site trying to figure out what is going on.i did have low oil psi.[40psi all rpm]
Re: engine taredown results, [Re: blownzoom440] #815107
09/28/10 09:47 PM
09/28/10 09:47 PM
ELYRIA,OH
ELYRIA,OH
the block is new Koleno and hope it is correct.thye line bore was measured with a bore mic.the crank is fresh back from moldex[440source] from being corrected .010/.010 and heat treated.Thanks for saying something!your thaughts appreciated!
Page 1 of 3 1 2 3
