Re: Small Block cam ?
[Re: UCUDANT]
#81495
06/29/08 10:47 AM
06/29/08 10:47 AM
Always degree a cam when installing it. It is of the utmost importance to firstly, know where TDC is EXACTLY, and second, to have that cam set up from the corrected TDC.
Aftermarket parts are notorious for pushing tolerance limits. Example....a new harmonic balancer on my 79 GT's 360....the balancer was out 2 degrees in the factory markings. I slipped an old Mope balancer on and re-ran the numbers.....the factory balancer was dead-on. I ran the numbers again using a 360 balancer a buddy had.....again the factory unit is spot on.
Back goes the new replacement unit.....run the numbers....still 2 degrees out. The simple fix is a timing tape around the new balancer.
Now....imagine if you just dropeed a cam into this without checking. We already have 2 degrees misalignment with one part....what if the cam is out by a degree or two as well? Then you have the possibility of being up to 4 degrees off of where the manufacturer wants his cam to run at. Then there are the ignition timing issues that would arise as well.
Comp Cams makes a nice kit for under a buck and a half, that allows you to set virtually any engine.
As UCUDANT pointed out....degreeing a cam isn't an overly difficult job, just tedious and exacting. But do it once or twice and you'll get a firm understanding of why it must be done.
Bad
#81496
06/29/08 09:50 PM
06/29/08 09:50 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
I agree degreeing a cam is good but for most street applications unnecessary.There are not millions but probally hundreds of millions of cars from the factory that never had a cam degreed.If you worked in a shop in the old days where it was common to do chains and cams you would starve or get fired if you tried to do it.Just line up the dots and set the timong when you were done.Now if you want to gain a bit more performance its a good idea but for a guy thats going to do a cam swap maybe once or twice a 150 buck investement for a street motor isnt a wise investment.Rocky
Chrysler Firepower
