Rocky, like you said I'm not changing the cam, but the new timing set, the crank gear has three different key ways to use. advance, normal, retarded. I'm just trying to figure out the best one to use. I was told that the factory had them retarded for emissions, so would that mean I use the normal setting?
09 Challenger B5 Classic 78 Magnum GT Check out my Website http://home.comcast.net/~tlyerk/troy1.html
