Cheapest way to convert fuel bowl sight windows? #814877
09/26/10 12:44 PM
09/26/10 12:44 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Will the Holley #34-37 kit work on a 1050 Dominator?
Is it possible to drill and tap the sides of my stock fuel bowls to fit these #26-112 sight windows? I believe they are one inch windows.
I miss the Quickfuel bowls on my last car with the glass windows. I don't have alot of money to spend on this and I won't use those plastic sight plugs.
Re: Cheapest way to convert fuel bowl sight windows? [Re: ProSport] #814878
09/26/10 01:21 PM
09/26/10 01:21 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
These will work. I have used them.
Re: Cheapest way to convert fuel bowl sight windows? [Re: ProSport] #814879
09/26/10 01:36 PM
09/26/10 01:36 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I have been wanting to do the same thing.
Re: Cheapest way to convert fuel bowl sight windows? [Re: ProSport] #814880
09/26/10 03:58 PM
09/26/10 03:58 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
For the $$$ difference it looks like the bowl kits are the way to go and I might even get those myself.
Re: Cheapest way to convert fuel bowl sight windows? [Re: Thumperdart] #814881
09/26/10 05:01 PM
09/26/10 05:01 PM
Tallmadge, Ohio
Butch Offline
Butch  Offline
Tallmadge, Ohio
Bob if you have the plastic screw in windows you can polish both sides them with plastic ploish. When finished they will be as clear as glass.
'74 Duster 440
'04 Hemi Quad Cab Ram
'06 Pacifica
'78 MGB
Re: Cheapest way to convert fuel bowl sight windows? [Re: Thumperdart] #814882
09/26/10 05:38 PM
09/26/10 05:38 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Dominic, your right, I'm just gonna save up for the whole kit. I got spoiled to the glass windows in my last car, so these stock bowls drive me crazy when trying to properly set the fuel bowl level, plus with the window you can always see what's going on in there, and if you want to try a higher than normal fuel level it is a piece of cake to set.
Butch your polished plugs look nice but I like a bigger window and I had one of those plastic ones break off in the hole and caused me alot of frustration so I'm gonna avoid those.
Re: Cheapest way to convert fuel bowl sight windows? [Re: Thumperdart] #814883
09/26/10 06:32 PM
09/26/10 06:32 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
bob here is a pic of my SV1 if ya can do anything like this!
Mopar Performance
Re: Cheapest way to convert fuel bowl sight windows? [Re: moparniac] #814884
09/26/10 07:25 PM
09/26/10 07:25 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Is that a snap ring? I'd have to have a groove in there for that I would think.
Re: Cheapest way to convert fuel bowl sight windows? [Re: ProSport] #814885
09/26/10 10:55 PM
09/26/10 10:55 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
I'm gonna order the whole fuel bowl kit from BIGS next week, may as well support the guy who built my awesome carb.
Re: Cheapest way to convert fuel bowl sight windows? [Re: ProSport] #814886
09/27/10 07:33 AM
09/27/10 07:33 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Since the window is bigger in dia,where is every one setting there level to? Did you scribe a line at the bottom of the old threads on the side of the bowl?
Re: Cheapest way to convert fuel bowl sight windows? [Re: ProSport] #814887
09/27/10 08:20 AM
09/27/10 08:20 AM
Delray beach, Florida
P
Performance Only Offline
P
your not saying you got an "awesome" custom built carb and it didn't come with clear sight plugs, are you?
machine shop owner and engine builder
Re: Cheapest way to convert fuel bowl sight windows? [Re: Performance Only] #814888
09/27/10 08:45 AM
09/27/10 08:45 AM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
No, I bought this carb used, and it is an old Holley 9375 that BIGS did some work on YEARS ago. It works great and Jesse has been awesome with answering questions and helping any way he can.
Re: Cheapest way to convert fuel bowl sight windows? [Re: RATTRAP] #814889
09/27/10 09:10 AM
09/27/10 09:10 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
i think the hole is moved up so the bottom is the same. not certain though
Re: Cheapest way to convert fuel bowl sight windows? [Re: Defbob] #814890
10/10/10 05:47 PM
10/10/10 05:47 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Sent the money order out Monday and the new bowls arrived from BIGS friday. I installed them today and went for a cruise. I run the fuel level a little less than half way up the window, I like to run it a little high so that's another benefit of the window, easier to set it high. But the biggest benefit is not spilling fuel on a hot engine while adjusting the level.
Re: Cheapest way to convert fuel bowl sight windows? [Re: ProSport] #814891
10/10/10 05:48 PM
10/10/10 05:48 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Also installed a new Quickfuel regulator. I'm wondering if I should cap off the barb on the regulator, it's for boost referenced fuel pressure.
Re: Cheapest way to convert fuel bowl sight windows? [Re: ProSport] #814892
10/10/10 05:49 PM
10/10/10 05:49 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
The barb
Re: Cheapest way to convert fuel bowl sight windows? [Re: ProSport] #814893
10/10/10 09:49 PM
10/10/10 09:49 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
it needs to be vented or the diaphram will be fighting pressure along with the spring
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Cheapest way to convert fuel bowl sight windows? [Re: ProSport] #814894
10/10/10 10:16 PM
10/10/10 10:16 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
nice fuel bowls
Mopar Performance
Re: Cheapest way to convert fuel bowl sight windows? [Re: bigtimeauto] #814895
10/10/10 11:40 PM
10/10/10 11:40 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Ok thanks
Re: Cheapest way to convert fuel bowl sight windows? [Re: ProSport] #814896
10/18/10 09:43 AM
10/18/10 09:43 AM
Oh
RacerGofKGB Offline
Got The Big One
RacerGofKGB  Offline
Got The Big One
Oh
Why not just buy sight plugs from McMaster-Carr? Drill and tap your bowls with the correct NPT thread. The plugs are only about $5-$10 each .
