A-Body 8 3/4 Axles #814631
09/26/10 12:50 AM
09/26/10 12:50 AM
Hurricane, WV
moparsrule Offline OP
Hurricane, WV
I have an 8 3/4 A-Body rear end with small bolt pattern that I want to install in a 74 Dart with big bolt pattern. I have been told that I can cut a little off of B-body axles and they will work in the A-body. Can anybody tell me if this will work? I want to install the rear but I don't have the money to buy new axles.
Re: A-Body 8 3/4 Axles [Re: moparsrule] #814632
09/26/10 01:00 AM
09/26/10 01:00 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
I have 4 options:
If your car is a dart sport you can use a b-body rear end no problems.
If not find a 8 1/4 big bolt pattern and build a rear end.
If the car is a regular dart use a b-body and buy the offset rims.
Save money and do it the right way.
All will work some easier than others.
Re: A-Body 8 3/4 Axles [Re: moparpollack] #814633
09/26/10 01:16 AM
09/26/10 01:16 AM
Hurricane, WV
Hurricane, WV
The car is a Dart Sport and I think it has an 8 1/4 in it now but I didn't know how strong they were. Is the B-body rear end not to wide for the Dart sport?
Re: A-Body 8 3/4 Axles [Re: moparsrule] #814634
09/26/10 01:51 AM
09/26/10 01:51 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Unless you are running serious power the 8-1/4 will be fine.
Re: A-Body 8 3/4 Axles [Re: moparsrule] #814635
09/26/10 03:10 AM
09/26/10 03:10 AM
85086
Lil Herman
Lil Herman
85086
On my 72 duster you can barely tell but nothing major. I put some wider wheels on with more backspace and it wasn't even noticeable.
Re: A-Body 8 3/4 Axles [Re: moparpollack] #814636
09/26/10 09:36 AM
09/26/10 09:36 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Have a competant machine shop redrill your present axles for the arge bolt pattern using 1/2 inch screw in studs. don't use the press in studs with the knurl. Using screw in studs will leave you very close to as much meat around the stud as you presently have. Unless yo will be making some very serious power you will have no problems with this.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: A-Body 8 3/4 Axles [Re: moparpollack] #814637
09/26/10 09:43 AM
09/26/10 09:43 AM
scratchnfotraction Offline
a set of moser axles with the large brake offset with the 5 on 4.5 wbp is one way..about 300$
not all B,C,D,E body axle are candidates for cut and respline
c-body and trucks are the best place to find them
pull a tape from the flanged end to the splined end of the axle
it must have 28" of axle before it tapper down to be cut to A-body specs
yes the cut and respine would be fine for a street cruzer but not to good for high HP raceing IMHO
remeber the a-body axle will become a 1/2 wider when you use the large brake offset axles,1/4" per side,so make sure the back set is correct when getting the rims
my A-body 8 3/4 with moser axles use a 7" rim with 4.5" backset on the rim in my 68 Dart
its in my 85 truck now and uses a 12" rim with the same 4.5 backset
dont for get the lipstick on the new 8 3/4 when you put it in
Re: A-Body 8 3/4 Axles [Re: scratchnfotraction] #814638
09/26/10 12:41 PM
09/26/10 12:41 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
If you don't have the money for new axles run the 8-1/4 or get your axles and drums redrilled.
You can also contact Dr. Diff on this board and see what he's got.
Big pattern axles for the 8-3/4 will also use B-body brakes unless you have them made with the smaller offset for the A-body brakes.
I have 2 sets of Moser A body axles, and also had them cut and respline a pair of E-body axles. Cut and spline is fine for a low power street car, but if you're making any real horsepower or using tires that hook well you will probably twist the splines.
Re: A-Body 8 3/4 Axles [Re: slantzilla] #814639
09/26/10 01:58 PM
09/26/10 01:58 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
With this approach, you lose the wheel hubcentricity.
There are low-cost A-body 4.5" BC axles out there (Yukon, etc.)
Since the Dart already has what are, effectively, B/E-body rear brakes, it will all then bolt together with a 8.75" A-body housing. Even stock Timken bearings.
I agree that the 8.25" will take a fair amount of abuse - down to, say, a mid/low-13-second car, it is fine.
Rick
Re: A-Body 8 3/4 Axles [Re: Rick_Ehrenberg] #814640
09/26/10 02:09 PM
09/26/10 02:09 PM
with this approach, you lose the wheel hubcentricity.
Rick w the tapered lug nuts locating the wheel is that going to be a prob w redrilling them to BBP? I've noticed alot of play from the hub register to the ID of the wheel center hole on my stock steel BBP wheels. Any thoughts
Re: A-Body 8 3/4 Axles [Re: RapidRobert] #814641
09/26/10 03:07 PM
09/26/10 03:07 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Most aftermarket and some OEM wheels (Magnum 500) are lug centric anyway.
Re: A-Body 8 3/4 Axles [Re: DoctorDiff] #814642
09/26/10 03:12 PM
09/26/10 03:12 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Yep....we build and sell hundreds of wheels in Oz, and they are lug centric only...all the 2 piece billet stuff we get just have a generic hub bore, and they go on all sorts of cars and never had a single issue (ditto for thousands of steel centers we sell to other wheel manufactures)
