Re: A-Body 8 3/4 Axles
[Re: moparsrule]
#814632
09/26/10 01:00 AM
09/26/10 01:00 AM
moparpollack
Lil Herman
Lil Herman
85086
I have 4 options: If your car is a dart sport you can use a b-body rear end no problems. If not find a 8 1/4 big bolt pattern and build a rear end. If the car is a regular dart use a b-body and buy the offset rims. Save money and do it the right way. All will work some easier than others.
[Re: moparsrule]
#814635
09/26/10 03:10 AM
09/26/10 03:10 AM
moparpollack
Lil Herman
Lil Herman
85086
On my 72 duster you can barely tell but nothing major. I put some wider wheels on with more backspace and it wasn't even noticeable.
[Re: moparpollack]
#814637
09/26/10 09:43 AM
09/26/10 09:43 AM
Posts: 15,487 Florida
scratchnfotraction
a set of moser axles with the large brake offset with the 5 on 4.5 wbp is one way..about 300$ not all B,C,D,E body axle are candidates for cut and respline c-body and trucks are the best place to find them pull a tape from the flanged end to the splined end of the axle it must have 28" of axle before it tapper down to be cut to A-body specs yes the cut and respine would be fine for a street cruzer but not to good for high HP raceing IMHO remeber the a-body axle will become a 1/2 wider when you use the large brake offset axles,1/4" per side,so make sure the back set is correct when getting the rims my A-body 8 3/4 with moser axles use a 7" rim with 4.5" backset on the rim in my 68 Dart its in my 85 truck now and uses a 12" rim with the same 4.5 backset dont for get the lipstick on the new 8 3/4 when you put it in
[Re: scratchnfotraction]
#814638
09/26/10 12:41 PM
09/26/10 12:41 PM
Posts: 20,179 Park Forest, IL
slantzilla
Park Forest, IL
If you don't have the money for new axles run the 8-1/4 or get your axles and drums redrilled. You can also contact Dr. Diff on this board and see what he's got. Big pattern axles for the 8-3/4 will also use B-body brakes unless you have them made with the smaller offset for the A-body brakes. I have 2 sets of Moser A body axles, and also had them cut and respline a pair of E-body axles. Cut and spline is fine for a low power street car, but if you're making any real horsepower or using tires that hook well you will probably twist the splines.
[Re: slantzilla]
#814639
09/26/10 01:58 PM
09/26/10 01:58 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
With this approach, you lose the wheel hubcentricity.
There are low-cost A-body 4.5" BC axles out there (Yukon, etc.)
Since the Dart already has what are, effectively, B/E-body rear brakes, it will all then bolt together with a 8.75" A-body housing. Even stock Timken bearings.
I agree that the 8.25" will take a fair amount of abuse - down to, say, a mid/low-13-second car, it is fine.
Rick
[Re: DoctorDiff]
#814642
09/26/10 03:12 PM
09/26/10 03:12 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Most aftermarket and some OEM wheels (Magnum 500) are lug centric anyway.
Yep....we build and sell hundreds of wheels in Oz, and they are lug centric only...all the 2 piece billet stuff we get just have a generic hub bore, and they go on all sorts of cars and never had a single issue (ditto for thousands of steel centers we sell to other wheel manufactures)
