904 tips #814427
09/25/10 10:56 PM
09/25/10 10:56 PM
Alton, IL
Dakota_Don Offline OP
Alton, IL
changing fluid in my 68 dart, was thinkin of cranking line psi 2 turns, can i do anything else with out getting a shift kit??
add type f fluid as well.
Re: 904 tips [Re: Dakota_Don] #814428
09/25/10 11:48 PM
09/25/10 11:48 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
You can pull the accumulator spring out and put a blocker rod in to keep the piston from moveing and that will firm up the 1-2 shift. While you are in there you should check and adjust both bands. Use type-F fluid to get a tad firmer shift.
Re: 904 tips [Re: HotRodDave] #814429
09/26/10 12:13 AM
09/26/10 12:13 AM
Alton, IL
Alton, IL
plan on the band adjust to, if i remember the rod is 3in?
