Re: 904 tips
[Re: Dakota_Don]
#814428
09/25/10 11:48 PM
09/25/10 11:48 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
You can pull the accumulator spring out and put a blocker rod in to keep the piston from moveing and that will firm up the 1-2 shift. While you are in there you should check and adjust both bands. Use type-F fluid to get a tad firmer shift.
