Re: THANKS QWK-ENUF{E-85 GOD}
[Re: Labratt]
#814336
09/25/10 11:22 PM
09/25/10 11:22 PM
Posts: 2,442 LOWELL IN
QWK_ENUF
LOWELL IN
wait till next sat when i bump the timing 2 deg and optimize the jetting can you say 9.59 or better
WAXER
[Re: MoparPitBull]
#814338
09/26/10 01:02 PM
09/26/10 01:02 PM
Posts: 16,928 NC
440Jim
NC
Congrats on the new best. I love running E85. Did you do back to back runs on the same day? Can you give us weather comparisons and time slip data from the gas to E85 runs? What size carbs on gas and E85? Good to hear E85 catching on. I have run it for 3 years (2008, 2009, 2010) after a test in the fall of 2007 convinced me it was a good idea.
[Re: 440Jim]
#814339
09/26/10 02:21 PM
09/26/10 02:21 PM
Posts: 1,305 Hobart,Indiana
MoparPitBull
Hollywood
Hollywood
Hobart,Indiana
gas 1050 dom. e-85 1050 dom. weather was very similar to norwalk except the humidity was a little higher yesterday. 60ft.-1.325 330ft.-3.965 1/8-6.155 1/8mph-111.96 1000-8.056 1/4-9.686 138.43
[Re: MoparPitBull]
#814340
09/26/10 02:26 PM
09/26/10 02:26 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Congrats!
Which carb do you guys like to convert, such as 9375, 8082 etc? I have a 9375 currently.
[Re: ProSport]
#814341
09/26/10 07:22 PM
09/26/10 07:22 PM
QWK_ENUF
LOWELL IN
3 circuit HP dommys are good but any is good.i will be conveting a 8082 next for a 2 circuit. a 9375 will work good.
WAXER
[Re: MoparPitBull]
#814344
09/27/10 12:32 PM
09/27/10 12:32 PM
Posts: 16,928 NC
440Jim
NC
That's an increase of almost 2 tenth's and 3 mph over norwalk last week.
The higher humidity on the E85 day would make the weather slower than the gas day. So the improvement is even better than the times alone.
[Re: racerx]
#814346
10/11/10 01:54 AM
10/11/10 01:54 AM
Posts: 1,855 Staten Island N.Y.
Dap
Staten Island N.Y.
How much compression do you guys have that run on E-85?. I am at 13.4:1 right now. Since reading these posts I have found a few E-85 stations within a reasonable driving distance. $2.45/Gal sure beats $9.00/Gal at the track.
PRH446 10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
