Why won't this crank balancer bolt stay tight? #813459
09/24/10 07:59 PM
09/24/10 07:59 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
This is an ARP bolt, I tightened it slowly with my fingers on the washer and it tightens up against the washer nicely before the bolt starts to get real tight, so it's not bottoming out and I don't need a thicker washer. After 2 passes down the 1/4 mile this thing comes loose, even after I thread locked it and torqued it.
I did notice that the crank snout is not flush with the harmonic balancer so the bolt/washer is tightening up against the balancer. I don't know if the balancer will go on any further, and my alternator belt is still lined up perfectly.
Re: Why won't this crank balancer bolt stay tight? [Re: ProSport] #813460
09/24/10 08:03 PM
09/24/10 08:03 PM
Brea, Ca
Dart Racer Offline
Dart Racer  Offline
Brea, Ca
Are you using a torque wrench to tighten or just "guessing" as you tighten by hand?
Mine came loose a couple of times until I used the torque wrench and proper torque on it.
Re: Why won't this crank balancer bolt stay tight? [Re: Dart Racer] #813461
09/24/10 08:11 PM
09/24/10 08:11 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Sounds like the damper is not on all the way. Or your not getting it torqued rite...
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: Why won't this crank balancer bolt stay tight? [Re: Dart Racer] #813462
09/24/10 08:36 PM
09/24/10 08:36 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Yes, using a torque wrench. I even tried putting a long bar on the end of my 1/2" drive ratchet and tightened the crap out of it. I'm gonna try to get the balancer on further tonite.
Re: Why won't this crank balancer bolt stay tight? [Re: ProSport] #813463
09/24/10 08:38 PM
09/24/10 08:38 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
It should seat on the balancer. How was the engine balanced? Harmonis wil loosen them too... Check your convertor bolts.
Re: Why won't this crank balancer bolt stay tight? [Re: moper] #813464
09/24/10 08:43 PM
09/24/10 08:43 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
x 2
Re: Why won't this crank balancer bolt stay tight? [Re: dOc …] #813465
09/24/10 08:47 PM
09/24/10 08:47 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
i was thinking about buying that bolt, then thought to myself, how tight would an ARP ballancer bolt need to be to stretch it so it wont vibrate out. i didnt buy it
Re: Why won't this crank balancer bolt stay tight? [Re: sixpackgut] #813466
09/24/10 08:54 PM
09/24/10 08:54 PM
Florida STAYcation
dOc … Offline
dOc …  Offline
Florida STAYcation
Just a quick Q .... how much deeper will the bolt go into the crank ... without using the washer ?
Re: Why won't this crank balancer bolt stay tight? [Re: dOc …] #813467
09/24/10 08:59 PM
09/24/10 08:59 PM
Arizona
Chris'sBarracuda Offline
Arizona
x 2
x3..
If the engine is out of balance it will vibrate out.. Been there done that..
Chris..
Re: Why won't this crank balancer bolt stay tight? [Re: Chris'sBarracuda] #813468
09/24/10 09:08 PM
09/24/10 09:08 PM
UK
602heavy Offline
602heavy  Offline
UK
Had this same issue , track marshall came to see me twice in the pits when i left the damper bolt on the track (twice )......the bolt was torqued 120ft lbs with the balancer real tight on crank snout , the damper was around 1/4" short of bottoming out on crank for correct belt alignment , in the end i had to bite the bullet & put a spacer between damper & crank , no more problems , was using the same ARP bolt in pic.
Re: Why won't this crank balancer bolt stay tight? [Re: 602heavy] #813469
09/24/10 09:14 PM
09/24/10 09:14 PM
NE Ohio
DoubleD Online content
DoubleD  Online Content
NE Ohio
What dampner are you running - I will bet you need the long bolt!
Re: Why won't this crank balancer bolt stay tight? [Re: ProSport] #813470
09/24/10 10:03 PM
09/24/10 10:03 PM
Some of the Mopar factory service manuals call for 120 Ft LBs torque and others call for 150 lbs, what are you torquing yours to? As already siad, try removing the washer and see if you can screw the bolt in pass the outer edge of the balancer, if you can it is not bottoming out. the bolt is suppose to be tighten up against the balancer, not tighten up by bottoming out You can also look at the first one or two threads on the end of the bolt that srews into the crankshaft, if there laid over and damaged it may be bottoming out if there good it isn't usually. Let us know what you have to do to fixed it, I had one (Hemi four speed car, race only, let the clutch out at 6000 + RPM and shifted it at 7000 RPM ) that wouldn't stay tight until I torqued to 150 lbs with blue loktite
Re: Why won't this crank balancer bolt stay tight? [Re: DoubleD] #813471
09/24/10 10:04 PM
09/24/10 10:04 PM
Tallmadge, Ohio
Butch Offline
Butch  Offline
Tallmadge, Ohio
Have you checked to make sure the bolt isn't bottoming out?
'74 Duster 440
'04 Hemi Quad Cab Ram
'06 Pacifica
'78 MGB
Re: Why won't this crank balancer bolt stay tight? [Re: DoubleD] #813472
09/25/10 01:45 AM
09/25/10 01:45 AM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
I'll check the bolt length tomorrow(bottoming out), the damper is a TCI Rattler. I was torqueing to 120 but also tried much higher with a long bar as I mentioned earlier.
Re: Why won't this crank balancer bolt stay tight? [Re: ProSport] #813473
09/25/10 08:50 AM
09/25/10 08:50 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I always use a impact to pull the damper on... I make
sure the bolt is near 3/8" to 1/2" from being bottomed out
and stack up washers to pull it on... that way I have
plenty of threads holding... the shock from the impact
really helps move the damper over a steady pressure
Re: Why won't this crank balancer bolt stay tight? [Re: MR_P_BODY] #813474
09/25/10 09:49 AM
09/25/10 09:49 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
pull the damper & check the crank snout now before you run the engine again. if it's got fretting on the snout you have a harmonics problem & it's good to catch it early. leave it too long & you've got a machining bill to add to your problem. ask me how i know?
Re: Why won't this crank balancer bolt stay tight? [Re: rebel] #813475
09/26/10 02:46 PM
09/26/10 02:46 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Everything looks clean and normal, and the bolt is NOT bottoming out. But this ARP bolt is 5/8" shorter than the factory bolt, so I'm gonna torque the factory bolt in there with thread lock and see how it goes.
Re: Why won't this crank balancer bolt stay tight? [Re: ProSport] #813476
09/26/10 03:01 PM
09/26/10 03:01 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
I have an ARP bolt (12 point)with the same TCI balancer that you do. I used the long bolt. mine has remained tight
