Why won't this crank balancer bolt stay tight?
#813459
09/24/10 07:59 PM
09/24/10 07:59 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
This is an ARP bolt, I tightened it slowly with my fingers on the washer and it tightens up against the washer nicely before the bolt starts to get real tight, so it's not bottoming out and I don't need a thicker washer. After 2 passes down the 1/4 mile this thing comes loose, even after I thread locked it and torqued it. I did notice that the crank snout is not flush with the harmonic balancer so the bolt/washer is tightening up against the balancer. I don't know if the balancer will go on any further, and my alternator belt is still lined up perfectly. ![](/ubbthreads/images/graemlins/shruggy.gif)
Re: Why won't this crank balancer bolt stay tight?
[Re: Dart Racer]
#813461
09/24/10 08:11 PM
09/24/10 08:11 PM
Posts: 452 Monrovia, So-Cal, USA
racerhog
Sounds like the damper is not on all the way. Or your not getting it torqued rite...
Bob(Cowboy)Hogan Monrovia So-Cal
[Re: Dart Racer]
#813462
09/24/10 08:36 PM
09/24/10 08:36 PM
ProSport
Akron, Ohio
Yes, using a torque wrench. I even tried putting a long bar on the end of my 1/2" drive ratchet and tightened the crap out of it. I'm gonna try to get the balancer on further tonite.
[Re: ProSport]
#813463
09/24/10 08:38 PM
09/24/10 08:38 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
It should seat on the balancer. How was the engine balanced? Harmonis wil loosen them too... Check your convertor bolts.
[Re: moper]
#813464
09/24/10 08:43 PM
09/24/10 08:43 PM
Posts: 30,492 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
x 2 ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: dOc …]
#813465
09/24/10 08:47 PM
09/24/10 08:47 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
i was thinking about buying that bolt, then thought to myself, how tight would an ARP ballancer bolt need to be to stretch it so it wont vibrate out. i didnt buy it
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: dOc …]
#813467
09/24/10 08:59 PM
09/24/10 08:59 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
x 2
x3..
If the engine is out of balance it will vibrate out.. Been there done that..
Chris.. ![](/ubbthreads/images/graemlins/wave.gif)
[Re: ProSport]
#813470
09/24/10 10:03 PM
09/24/10 10:03 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
Some of the Mopar factory service manuals call for 120 Ft LBs torque and others call for 150 lbs, what are you torquing yours to? As already siad, try removing the washer and see if you can screw the bolt in pass the outer edge of the balancer, if you can it is not bottoming out. the bolt is suppose to be tighten up against the balancer, not tighten up by bottoming out ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) You can also look at the first one or two threads on the end of the bolt that srews into the crankshaft, if there laid over and damaged it may be bottoming out ![](/ubbthreads/images/graemlins/scope.gif) if there good it isn't usually. Let us know what you have to do to fixed it, I had one (Hemi four speed car, race only, let the clutch out at 6000 + RPM and shifted it at 7000 RPM ![](/ubbthreads/images/graemlins/3_2_116.gif) ) that wouldn't stay tight until I torqued to 150 lbs with blue loktite ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: DoubleD]
#813471
09/24/10 10:04 PM
09/24/10 10:04 PM
Posts: 1,371 Tallmadge, Ohio
Butch
Tallmadge, Ohio
Have you checked to make sure the bolt isn't bottoming out?
'74 Duster 440 '04 Hemi Quad Cab Ram '06 Pacifica '78 MGB
[Re: DoubleD]
#813472
09/25/10 01:45 AM
09/25/10 01:45 AM
ProSport
Akron, Ohio
I'll check the bolt length tomorrow(bottoming out), the damper is a TCI Rattler. I was torqueing to 120 but also tried much higher with a long bar as I mentioned earlier.
[Re: ProSport]
#813473
09/25/10 08:50 AM
09/25/10 08:50 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I always use a impact to pull the damper on... I make sure the bolt is near 3/8" to 1/2" from being bottomed out and stack up washers to pull it on... that way I have plenty of threads holding... the shock from the impact really helps move the damper over a steady pressure ![](/ubbthreads/images/graemlins/wave.gif)
