Best way for SB timing chain gasket with oil pan on? #813226
09/24/10 11:14 AM
09/24/10 11:14 AM
Outside
thedriver Offline OP
Outside
changing the timin chain gasket on my 340, i've done this before and remember it bein a pain in the heiny with the oil pan on., that rubber front pan seal always wants to roll around.
Anyone know any tricks to make that rubber oil pan seal stay in place easier? i know, push the rubber nipples into the pan, the bottom middle always seems to wanna roll into the pan when i slide the timing chain cover on!
suggestions!??
1973 challenger
Dana. 4 speed. Low deck.
Re: Best way for SB timing chain gasket with oil pan on? [Re: thedriver] #813227
09/24/10 12:02 PM
09/24/10 12:02 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Lift the cover into the crank seal some and then get into place front to back then set down on the pan rail. Don't slide it in. Small dab of silicone in the corners where the cover meets the block.
Re: Best way for SB timing chain gasket with oil pan on? [Re: MoparforLife] #813228
09/24/10 12:14 PM
09/24/10 12:14 PM
Outside
Outside
1973 challenger
Re: Best way for SB timing chain gasket with oil pan on? [Re: MoparforLife] #813229
09/24/10 03:12 PM
09/24/10 03:12 PM
Under My Car
Mopar_Country Offline
Under My Car
Also be sure and lube the crank seal so it's not dry on start up.
