moroso ceramic engine sealer????????????????????? #812945
09/23/10 09:04 PM
09/23/10 09:04 PM
ohio
all spooled up Offline OP
ohio
i have a head gasket leaking its a o ring block copper head gasket leaking water not real bad but a leak any pointers on useing this stuff..
Re: moroso ceramic engine sealer????????????????????? [Re: all spooled up] #812946
09/23/10 09:14 PM
09/23/10 09:14 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i am in the same boat but with the cylinder pressure pushing into the water i dont think it works that way.
edit:unles you just have a leak from the lack of gasket seal.
Re: moroso ceramic engine sealer????????????????????? [Re: blownzoom440] #812947
09/23/10 09:19 PM
09/23/10 09:19 PM
ohio
ohio
its leaking on the out side only between 6 and 8 cly water jacket....
Re: moroso ceramic engine sealer????????????????????? [Re: blownzoom440] #812948
09/23/10 09:25 PM
09/23/10 09:25 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
My car popped a head gasket water leak last thursday night, I also have an o-ringed block with aluminum heads and copper head gaskets. The Yamabond4 sealant has held up great all summer til last thursday. I ran around the corner to Summit Racing and bought a bottle of Moroso ceramic sealer, shook it up good(this is critical), took some water out of the radiator to make room for the ceramic stuff, ran the engine up to 150 degrees, poured the ceramic sealer in and let the motor run for at least 15 minutes. The leak stopped after only 5 minutes.
I shut it off and let it cool, pulled the lower radiator hose off and let out as much as possible, put hose back on and filled the radiator with fresh water. I loaded it on the trailer and it was good to go.
Re: moroso ceramic engine sealer????????????????????? [Re: all spooled up] #812949
09/23/10 09:28 PM
09/23/10 09:28 PM
ELYRIA,OH
ELYRIA,OH
that should work.sorry to interump!
Re: moroso ceramic engine sealer????????????????????? [Re: blownzoom440] #812950
09/23/10 09:33 PM
09/23/10 09:33 PM
ohio
ohio
no big thing
Re: moroso ceramic engine sealer????????????????????? [Re: all spooled up] #812951
09/23/10 10:23 PM
09/23/10 10:23 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I used BARR"S block sealer. once it's in we used a pressure tester to keep 7lb on the system. forcing any sealer directly to the leak. works every time
home of the
Sox and Martin Hemi Duster
