'69 Dodge Charger 727 - Throttle Lever & Shaft #81167
06/28/08 08:24 PM
06/28/08 08:24 PM
Toronto, ON
Shakey Offline OP
Shakey  Offline OP
Toronto, ON
I am ready to adjust the throttle linkages on my '69 Charger 440 with the 727 Torqueflite using the procedures from the 1969 Service Manual. I located the procedure on page 21-53 and I have run into an issue with the very first step.
Step 3 - Hold the transmission lever (part # 11) firmly forward against its stop.
Here is where I have the problem.
The lever has spring tension when I move it towards the back of the car however when I push it forward it goes as far as it can and rests against the body of the transmission. I don't feel a "stop" as the service manual suggests.
Has anyone experienced this before?
1969 Dodge Charger R/T SE - 440 AUTO
Re: '69 Dodge Charger 727 - Throttle Lever & Shaft [Re: Shakey] #81168
06/28/08 11:15 PM
06/28/08 11:15 PM
Toronto, ON
Shakey Offline OP
Shakey  Offline OP
Toronto, ON
Maybe this photo will help.
The shorter of the two levers moves all the way forward.
Is this normal?
Re: '69 Dodge Charger 727 - Throttle Lever & Shaft [Re: Shakey] #81169
06/29/08 12:31 PM
06/29/08 12:31 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
When it won't move any further forward that's the stop they mean.
Re: '69 Dodge Charger 727 - Throttle Lever & Shaft [Re: Shakey] #81170
06/29/08 04:50 PM
06/29/08 04:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
When you say the lever "rests against the body of the transmission" where does it make contact? Near the pointed end of the yellow arrow shown?
If the lever swings far enough forward to contact the case in that area, the shaft the lever is attached to could have a broken weld inside the trans. The shaft is welded to a cam and the weld often breaks.
Another possibility is that the tang on the cam is not making contact with the stop screw on the valve body; in either case the pan will have to be removed for inspection.
Re: '69 Dodge Charger 727 - Throttle Lever & Shaft [Re: John_Kunkel] #81171
06/29/08 07:55 PM
06/29/08 07:55 PM
Toronto, ON
Shakey Offline OP
Shakey  Offline OP
Toronto, ON
If it wern't for the plug in the way, yes it would hit the casing.
I'm guessing the cam is missing my stop screw or my stop screw is missing.
Thank you.
