2000 Dodge Dakota fuel tank #811598
09/22/10 10:01 AM
09/22/10 10:01 AM
Quantico, VA
ParaFrog88 Offline OP
Quantico, VA
I blew the engine in my Dakota with a full tank of gas. How can I get the fuel pump to run so I can drain the tank before I junk it since gas is 2.70 a gal.
1967 Coronet R/T 1970 Coronet R/T 1997 Dakota 2006 Ram 3500 DRW
Re: 2000 Dodge Dakota fuel tank [Re: ParaFrog88] #811599
09/22/10 10:04 AM
09/22/10 10:04 AM
S.E.Ohio
Magnumguy Online content
Magnumguy  Online Content
S.E.Ohio
If you're junking it, poke a hole in the tank and have buckets on hand.
Won't the pump run when you turn on the key to prime up?
YOU have a PM
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: 2000 Dodge Dakota fuel tank [Re: ParaFrog88] #811600
09/22/10 10:05 AM
09/22/10 10:05 AM
Just South of The Motor City
limechallenger Offline
If your going to junk it ,why not punch a hole in it! the scrap yard will !
70 T/A Challenger 78 Aspen R/T 87 Indy 500 Dakota
Re: 2000 Dodge Dakota fuel tank [Re: ParaFrog88] #811601
09/22/10 10:24 AM
09/22/10 10:24 AM
Ohio
Todd Offline
Todd  Offline
Ohio
Remove the fuel line at any accesible point and jump the fuel pump relay with a piece of wire. JMO
