Re: 1/8 mile. Speed 78 mph.
[Re: Cuda67]
#811044
09/22/10 08:07 AM
09/22/10 08:07 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Hi and thanks for any help. A friend of mine has a 66 Coronet that according to him using a gps and it told him that at 1/8 mile he was going 78 mph. The car is a 440 with a 484/284 cam. 3.55 rear and a 750 holley with 9.5 or so compression. It has some kind of very cheap plastic and aluminum pistons. Any idea what it would do in a 1/4. Probably a hard question to answer, had to ask. Also he wants to race my 67 Barracuda, and it has a 383, same cam and rear but smaller dia tires. Does have a 770 holley and 10.5 compression. I don't want to race him fearing the results will reall make him mad. He keeps bugging me. Thanks again Ray
if he doesn't have a converter you should take him. Tell him if he wants his car to run yank that poo poo cam and get a cheap Summit 488 cam. He'll drop over a second off his et. Both of you should be runing at least a 3000 stall.
[Re: Cuda67]
#811045
09/22/10 04:00 PM
09/22/10 04:00 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
The GPS is giving him an exact speed where the drag strip gives you an average speed over a distance. The GPS speed will be slightly higher at the 1/8 and 1/4 mile traps.
Something to keep in mind.
[Re: Cuda67]
#811048
09/22/10 08:34 PM
09/22/10 08:34 PM
Mr.Yuck
Brookeville, Md
Would the Summit 488 help my Cuda? I am sure I can take his car as they sit. He is going to the track this week-end providing it doesn't rain
depends on the combo. If you have a low compression (less than 9.5:1) car with less than a 3000k stall and 3.91's yes. The cam pulls great. I went from 14.19 to 13.38 with a swap alone. I had the mopar 484 9:1 440 w/ 906 heads, headers, CH4b intake and eddy 750. I swaped the cam for the 488 and that was it. Later I added fresh air, dropped me to 13.11 then a 750DP to 12.90. (67 coronet)
