Another round of 'Name that Part!' #81088
06/28/08 07:39 PM
06/28/08 07:39 PM
OK
David_Trimble Offline OP
OK
Ok, I'm trying to remember what these were for, and failing miserably in the process... but then again I probably removed them from the car over 7 years ago when I first stripped the interior to get the car painted, so that's a stretch Anyone have a clue as to what they were used on?
I should've thrown in a ruler in the photo- sorry about that- but each 'O' ring is about 1/2" in diameter and roughly 1/8" thick. They're not exactly shaped like 'O' rings as they're flat, like they were cut from a length of rubber tubing (but weren't). Also, each ring has 3 small projections in the inner circumfrence.
WHat I know of them is:
1) They're out of a '69 Dodge Charger
2) They're part of the interior. BUT I have no idea exactly where in the interior they're from. I might add that while I dont think they're part of the door/window mechanisms, there is a small chance that they could be and that I'm wrong about that.
3) I have 2 of them, so I'm assuming that only 2 were used per car.
If anyone needs better photos, I'll see what I can do.
Thanks much!
David
'69 Dodge Charger R/T
Re: Another round of 'Name that Part!' [Re: David_Trimble] #81089
06/28/08 07:44 PM
06/28/08 07:44 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
seat belt bolt spacers?
perception is 90% of reality
Re: Another round of 'Name that Part!' [Re: Mr T2U] #81090
06/28/08 07:50 PM
06/28/08 07:50 PM
OK
OK
Good guess! But nowhere big enough to fit on a seat belt anchor bolt....
Re: Another round of 'Name that Part!' [Re: David_Trimble] #81091
06/28/08 07:59 PM
06/28/08 07:59 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Are they the little things that go on the instrument cluster..between the housing and the bezel to kinda seal it for the turn signal bulbs?
If that makes sense.
Re: Another round of 'Name that Part!' [Re: OzHemi] #81092
06/28/08 08:02 PM
06/28/08 08:02 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
That was my first thought, too. But upon closer inspection they look too thick and have the 3 prongs on them....
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Another round of 'Name that Part!' [Re: wingman] #81093
06/28/08 08:27 PM
06/28/08 08:27 PM
OK
OK
Oh- yea I know what you mean (I've had my instrument panel apart before), but no- they aren't. Those IP rings I think are somewhat larger (~1" dia?).
Re: Another round of 'Name that Part!' [Re: wingman] #81094
06/28/08 08:28 PM
06/28/08 08:28 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
With the car being from the hippie era, they almost look like the seals from the small plastic bongs sold in the 70`s, anything else odd found in the car?
Re: Another round of 'Name that Part!' [Re: quick77rt ] #81095
06/28/08 08:31 PM
06/28/08 08:31 PM
OK
OK
Fortunately (or unfortunately, depending on your point of view) no, didn't find anything non-Mopar issue when I tore out the interior. However, I did find a couple of Miller beer 'pony' bottles hiding in the rear passenger quarter panel....
Re: Another round of 'Name that Part!' [Re: David_Trimble] #81096
06/28/08 09:00 PM
06/28/08 09:00 PM
dave
can you email a bigger clearer picture
tom
rtspec@epix.net
Re: Another round of 'Name that Part!' #81097
06/28/08 09:37 PM
06/28/08 09:37 PM
OK
OK
dave
tom
rtspec@epix.net
On it's way!
