Ok, I'm trying to remember what these were for, and failing miserably in the process... but then again I probably removed them from the car over 7 years ago when I first stripped the interior to get the car painted, so that's a stretch
Anyone have a clue as to what they were used on?
I should've thrown in a ruler in the photo- sorry about that- but each 'O' ring is about 1/2" in diameter and roughly 1/8" thick. They're not exactly shaped like 'O' rings as they're flat, like they were cut from a length of rubber tubing (but weren't). Also, each ring has 3 small projections in the inner circumfrence.
WHat I know of them is:
1) They're out of a '69 Dodge Charger
2) They're part of the interior. BUT I have no idea exactly where in the interior they're from. I might add that while I dont think they're part of the door/window mechanisms, there is a small chance that they could be and that I'm wrong about that.
3) I have 2 of them, so I'm assuming that only 2 were used per car.
If anyone needs better photos, I'll see what I can do.
Thanks much!
David
