Re: Started My Build For Next Years Drag Week ...UPDATE
[Re: HardcoreB]
#810895
05/12/11 10:59 AM
05/12/11 10:59 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I was looking at the pics last night...Wow Mike, that thing looks good on the ground! Good work.
Thanks Sean... I'm gonna true up the axle housing today and get that done so I can order up the axles... it should be a rolling chassis in a few days... the last couple of bars(rear bars from the top of the main hoop to the very rear, tail gate) have to go in when the body is being lowered on cause they go through the back window.... the 2 door bars go in the very last thing so its easier to work inside... I'll start on my fuel tank in a day or so... making that out of alum diamond plate.... so its coming along
[Re: Moparnut426]
#810896
05/12/11 11:03 AM
05/12/11 11:03 AM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
Looking good. You will be done before me at the rate your going lol. And I started YEARs ago I need a bigger screen on this phone to really see your craftmanship. is this moly? I miss'd that part. I think your going to have another nice ride when your done.
[Re: FastmOp]
#810897
05/12/11 11:13 AM
05/12/11 11:13 AM
MR_P_BODY
Yeah its all moly... I wanted to keep the total weight at or below 2800# with me in it... I'm trying to keep MOST of the stock interior in it but some things will need to be changed around... like the heater box will get mounted behind the cab and plumbed into the dash for the defrosters
[Re: MR_P_BODY]
#810898
05/20/11 05:56 PM
05/20/11 05:56 PM
MR_P_BODY
Well this is where it stands today... got the rear end ready and was fitting the bed cover... cant put it on till I get the tubs in place
[Re: MR_P_BODY]
#810899
05/20/11 05:58 PM
05/20/11 05:58 PM
MR_P_BODY
One more for today EDIT the rear section thats open will be on a hinge and have a pair of cyl to hold it open... this will give me access to the fuel tank and battery
[Re: MR_P_BODY]
#810904
05/21/11 12:29 AM
05/21/11 12:29 AM
Posts: 1,845 Tampa
DusterDave
Tampa
Mike, you are a man on a mission!!! I am impressed by the amount of progress you have made!!! Keep the pics coming!
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: DusterDave]
#810905
05/21/11 08:29 AM
05/21/11 08:29 AM
MR_P_BODY
Thanks... I wanted to have it done for the drag week but we arent going this year but I still want to try and keep on my time line... wont be long and I'll be working on the nicer parts of building a car
[Re: MR_P_BODY]
#810906
05/28/11 11:58 AM
05/28/11 11:58 AM
MR_P_BODY
Here's my fuel tank I'm building... still need to add the cap in the center(hasnt come yet) and you can see my sending unit which I made to fit this tank
[Re: MR_P_BODY]
#810908
05/28/11 12:03 PM
05/28/11 12:03 PM
MR_P_BODY
This pic is with the frame section over it... this will have diamond plate on it also with a hinge to open for access to the tank and battery(battery will mount just forward of the tank)
[Re: Labratt]
#810911
05/28/11 07:01 PM
05/28/11 07:01 PM
MR_P_BODY
Raff..love the diamond plate! I'm going to try to make a visit next week..I have to pick up my hood on Tuesday from the paint shop,so wednesday-friday. I'll be in touch! Have a GREAT week end,Buddy!
Randy you have a good one also.... swing over any time.... you know where I always at
[Re: 1Fast340]
#810913
05/28/11 08:15 PM
05/28/11 08:15 PM
MR_P_BODY
you keep on surprising with how quick you build and the results look fantastic!
Thanks... its gonna slow down some... the money is getting short... but I have most of all of it... still need to get the crank balanced then I'll build the engine
Re: Started My Build For Next Years Drag Week ..6/3/11
[Re: MR_P_BODY]
#810914
06/02/11 10:11 PM
06/02/11 10:11 PM
MR_P_BODY
IT ROLLS here it is OUTSIDE of the shop... I'll do some sand blasting today on the rear sheet metal so I can fix a couple rust spots
