Page 2 of 4 1 2 3 4
Re: torsion bar removal tool [Re: earlybee] #80959
06/28/08 11:48 PM
06/28/08 11:48 PM
Interesting, so even if teeth marks were evident, no matter how light, you would replace them.
Re: torsion bar removal tool [Re: earlybee] #80960
06/28/08 11:49 PM
06/28/08 11:49 PM
California
P
polkat Offline
mopar addict
polkat  Offline
mopar addict
P
California
I use the vice grips as well, but I use a thick and rather hard piece of leather between the bar and the vice grips. Works well and no teeth marks at all.
Re: torsion bar removal tool #80961
06/28/08 11:56 PM
06/28/08 11:56 PM
IMGTX Online content
IMGTX  Online Content
Small Scratches can become big cracks very fast in a piece of metal under stress. Hence the reason for polishing Rod sides etc.
Re: torsion bar removal tool [Re: IMGTX] #80962
06/29/08 03:47 PM
06/29/08 03:47 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
Scratches caused by tools etc cause stress marks that can cause failure. If the Vise grips don't leave marks then no harm done. Most tools do not have serations on them just flats to prevent scratches.
I never used a tool, ever. I always loosened the LCA and slid it back if the bar didn't come out on it's own. Many people don't clean the rear of the Tbar socket or release the Tbar completely by removeing the UCA stop. If you don't you will need the tool.
up north where the t-bars and hex sockets become one with rust the only way to get it out is the tool, or if you ever bent them racing, from wheelly pops, they wont be easy to get out. to monkey with loosing up lcas, to tap it all back, you will have to take apart sway bar links,strut rods,brakes,wheel,lower ball joint,ect...with tool its 5 minute job, dont even have to take front wheel off.jack up car, impact t-bar jack bolt loose,clamp on tool, remove rear clip, and tap out towards rear
MOPAR OR NO CAR
Re: torsion bar removal tool [Re: earlybee] #80963
06/29/08 04:06 PM
06/29/08 04:06 PM
Pizza Bucket
snuggles Offline
snuggles  Offline
Pizza Bucket
Well, the teeth marks cause fatigue cracks over time. You may get lucky for a while but the snap failure at any time will make you wiser if you live thru it.
I had a bar snap but was in my own drive. I neverr had them out of that car.
Re: torsion bar removal tool [Re: snuggles] #80964
06/29/08 09:24 PM
06/29/08 09:24 PM
It seems I'll be spending a few bucks on T-bars now, great! Not to jack the original posters thread, but any ideas where to get a pair, and should I stay with the stock size, or go up a size or two on the diameter. Thanks.
Re: torsion bar removal tool #80965
06/29/08 10:10 PM
06/29/08 10:10 PM
hemigod426 Offline
hemigod426  Offline
mancini 440+6 car 920s hemi car 960s, or to improve handing on any b-body go with 920s
MOPAR OR NO CAR
Re: torsion bar removal tool [Re: hemigod426] #80966
06/29/08 10:30 PM
06/29/08 10:30 PM
383 car, I guess the same as 440?
Re: torsion bar removal tool #80967
06/29/08 10:51 PM
06/29/08 10:51 PM
The 383's used a smaller Tbar from the factory but there is no reason you can't move up or down as you like. They are the same length just different diameter in the mid section so nothing has to be changed for the thicker bar to work.
Re: torsion bar removal tool [Re: IMGTX] #80968
06/29/08 11:08 PM
06/29/08 11:08 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
I made my own tool out of aluminum block. It just has a half circle cut into both halves and clamps down on the bar. Seemed to work pretty nice on the last project. Will be using it again this winter.
Re: torsion bar removal tool #80969
06/29/08 11:13 PM
06/29/08 11:13 PM
hemigod426 Offline
hemigod426  Offline
all mopars have 1.250 hex ends bars. a body=35.8 long,b+e=41 long, c body 47 long. the type of car will mater. lets says its 383 4bbl b-body there only .860 size, go with the biggest stock size 920 440/hemi hd repop bars. with all bigger wheels now than stock 90% were 14 inch,faster steering parts, disc brake convertions,changed instant over centers in chassis. all mopars need bigger t-bars with these increased suspension demands
MOPAR OR NO CAR
Re: torsion bar removal tool #80970
06/29/08 11:17 PM
06/29/08 11:17 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
I got a set of 960s from Monicatti after looking for the best deal. Their a board sponsor here so tell them your a member, Torsion Bar Set - 0.960
Price:$177.65
Part Number :P5249158 http://www.monicattichrysler.com/comersus/store/comersus_searchItem.asp Type in torsion bar in the search box.
Re: torsion bar removal tool [Re: earlybee] #80971
06/30/08 08:53 AM
06/30/08 08:53 AM
Pizza Bucket
snuggles Offline
snuggles  Offline
Pizza Bucket
can bars with small nicks be dressed?
Re: torsion bar removal tool [Re: earlybee] #80972
06/30/08 09:05 AM
06/30/08 09:05 AM
Thanks for the advice Hemigod426, front disc brake conversion is probably in the future. Also thanks very much earlybee for the hook on the t-bars. The .960 are probably the way to go. Do I need a discount code, and where would I get one?
Re: torsion bar removal tool [Re: snuggles] #80973
08/09/08 03:27 PM
08/09/08 03:27 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
According to the FSM, they can. My 1967 manual says:
"Inspect torsion bars for scores and nicks. Dress down all scratches and nicks to remove sharp edges, then paint repaired area with a good rust preventative."
Re: torsion bar removal tool [Re: Fab64] #80974
08/09/08 04:08 PM
08/09/08 04:08 PM
Los Angeles, CA
Mobarge Offline
Mobarge  Offline
Los Angeles, CA
Whatever you do, be sure to get the tool. Hemigod's looks a lot better than the other one I bought years ago. Nice and solid. I destroyed the other tool I bought after using it a couple of times.
And, while the bars are out, why not do the .92 torsion bar upgrade. I did, and it was totally worth it.
'71 SSP - SOLD!
Re: torsion bar removal tool [Re: CYACOP] #80975
08/09/08 05:16 PM
08/09/08 05:16 PM
Arizona
anmracing Offline
anmracing  Offline
Arizona
Ours came out without a tool also.... I didn't even know that there was a special tool for that job. We took all the weight of the front end losened up the adjustment bolts and took out the clips. Came right out. Drives pretty good for 40 year old car.....
Re: torsion bar removal tool [Re: anmracing] #80976
12/22/10 08:37 PM
12/22/10 08:37 PM
Northern NJ
68 Sat Offline
68 Sat  Offline
Northern NJ
Does anyone know how to get in touch with Hemigod 426 I am trying to but his tool to get moving on my project...
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor 1969 Dodge Coronet 500 1956 Desoto Hemi 1955 Chrysler C300
Re: torsion bar removal tool [Re: 68 Sat] #80977
12/22/10 08:47 PM
12/22/10 08:47 PM
BDW Online content
BDW  Online Content
Click on his user name and PM him
hbullet1968@aol.com
Re: torsion bar removal tool [Re: BDW] #80978
12/22/10 09:14 PM
12/22/10 09:14 PM
Northern NJ
68 Sat Offline
68 Sat  Offline
Northern NJ
Don't waste your time with any other contraption then Hemigods removal tool. I used it last night to remove my torsion bars and it works liked a charm. Really well built and saved my ass. Just buy it
Page 2 of 4 1 2 3 4
