my 318 hit 12's and ran a road course
#809555
09/20/10 05:24 PM
09/20/10 05:24 PM
Posts: 1,397 Toronto Ontario, Can
Glen440
Last month my 318 magnum ran 13.5@102. I changed the vac carb to a double pumper because the 60' was 2.0. It worked and went 1.88 60' and 13.19@1o4 first pass. I also made a ram air air cleaner and that got a 13.05@105 so I pulled the air filter and power steering belt and got 12.998@ 106.3. Its a stock 98 318, with a little porting, comp xr265 roller, air gap intake, 750 dp, headers, 2.5" exhaust, 3000 stall, 727, 4.10 gear with 28" dot slick. At 6pm sat they let us do some free lapping on the road course. I put my street tires on which are 295/50R15 on back and 275/50R15 on the front. I burned the brakes up in 3 laps the first time out. I let it cool and did 7 or 8 laps and didn't use the brakes hard. Car handles extremely well but I think I broke the drag shocks. I want to put a front sway bar on it and good shocks and do it again. I could hit 100mph on both straights. I saw my shift light in 2nd on another stretch in the middle so thats around 80 mph. I ran it as a 2barrel because low speed in 2nd and flooring it would bog. I basically ran 2nd gear except on the straights.
87 dakota 6.1 hemi
Re: my 318 hit 12's and ran a road course
[Re: Glen440]
#809556
09/20/10 08:05 PM
09/20/10 08:05 PM
Posts: 583 Raleigh, NC
rockerbob
Raleigh, NC
Being a fellow 318 racer I'm interested in your progress. What was the temp & track conditions when you recorded these improvements. Also the weight of the car if I may ask. Thanks
2005 Dakota 4X4 3.7
2004 Rumble Bee 5.7
1978 Diplomat 318
1969 Satellite 318 "bracket racer"
1966 Barracuda (in progress )
1964 Dodge 330 (future race project)
1962 Belvedere (HUM????)
[Re: MoparforLife]
#809560
09/20/10 11:23 PM
09/20/10 11:23 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
I would like to see what that would do with a 650 double pumper. May help your low end.
I agree 100%, i've got just about the same combo & race weight, that car has 12.5s in it, i'm running a 360 magnum with stock lowerend, RHS heads, RPM knockoff, small roller, stock valvetrain, headers, 2800 11" PTC, 904, 3.73 gears with a 27" MT DR, car runs 12.5s/12.6s @ 104/105, 60fts around 1.82, best of a 1.79, this is shifting at 5100, & YES it has a 650dp & the 60ft. is alot better then a 750 3310, i'm sure that 750 is hurting your 60ft. Theres still alot of tricks i can do with this combo & knock off a couple tenths, just having fun running alittle juice through it right now .
I see you gained a tenth with a homemade cold-air setup, how did you do it? Any pics?
