Last month my 318 magnum ran
13.5@102. I changed the vac carb to a double pumper because the 60' was 2.0. It worked and went 1.88 60' and
13.19@1o4 first pass. I also made a ram air air cleaner and that got a
13.05@105 so I pulled the air filter and power steering belt and got 12.998@ 106.3.
Its a stock 98 318, with a little porting, comp xr265 roller, air gap intake, 750 dp, headers, 2.5" exhaust, 3000 stall, 727, 4.10 gear with 28" dot slick.
At 6pm sat they let us do some free lapping on the road course. I put my street tires on which are 295/50R15 on back and 275/50R15 on the front.
I burned the brakes up in 3 laps the first time out. I let it cool and did 7 or 8 laps and didn't use the brakes hard. Car handles extremely well but I think I broke the drag shocks. I want to put a front sway bar on it and good shocks and do it again. I could hit 100mph on both straights. I saw my shift light in 2nd on another stretch in the middle so thats around 80 mph. I ran it as a 2barrel because low speed in 2nd and flooring it would bog. I basically ran 2nd gear except on the straights.
