rim how wide for 9 in slicks? #808521
09/19/10 08:43 PM
09/19/10 08:43 PM
New Jersey, USA
Y
yella71 Offline OP
yella71  Offline OP
Y
New Jersey, USA
I recently picked up a set of 28x9x15 goodyear slicks and put them on 15x7 wheels that I had a 9in wide street tire on and it looks too narrow. Anyone know how wide the rim should be? I have 9 in wide rims, not sure which rims to use
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: rim how wide for 9 in slicks? [Re: yella71] #808522
09/19/10 08:54 PM
09/19/10 08:54 PM
Oconomowoc, WI.
Cudahlr Offline
Cudahlr  Offline
Oconomowoc, WI.
I run 8" wide rims.
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp
1985 Harley Sportster Bobber
2006 Ram 2500 sport - The Cudahlr
Re: rim how wide for 9 in slicks? [Re: Cudahlr] #808523
09/19/10 08:56 PM
09/19/10 08:56 PM
Great Lakes Region
abodiesonly1 Offline
Great Lakes Region
+/- 1 in.
Re: rim how wide for 9 in slicks? [Re: abodiesonly1] #808524
09/19/10 09:19 PM
09/19/10 09:19 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
10" will roll faster
Re: rim how wide for 9 in slicks? [Re: yella71] #808525
09/19/10 09:54 PM
09/19/10 09:54 PM
Locomotion Offline
Locomotion  Offline
Many Stock class racers, where 9" tires are the max allowed, use 10" rims. You can run more air which will make a stiffer, longer lasting sidewall, still get a good footprint after fine-tuning and it will be more stable on the top end. It may also help quicken RT's and 60' time by a little bit because, if everything else is working properly, the car is being propelled forward instead of time and HP being wasted and absorbed in wrinkling slicks!
One other factor that 10" rims and more air will affect, (again, just a little bit, but something nonetheless) is that they will grow a little less than slicks on narrow rims & less air, resulting in a little more finish line rpm
Re: rim how wide for 9 in slicks? [Re: Locomotion] #808526
09/20/10 12:07 AM
09/20/10 12:07 AM
when it comes to rim width on drag tires wider is better than narrower I used ten inch rims on my stocker back in the 1980s, some use 11 or 12 inch rims now
Re: rim how wide for 9 in slicks? [Re: Cab_Burge] #808527
09/20/10 12:53 AM
09/20/10 12:53 AM
Bama
Randy.. Offline
Randy..  Offline
Bama
iv'e got 10.5s on 12s on the dart.
