Finally got someone to watch over me on my first run through setting the lash on the new stroker (amazing things happen once you've got a couple of kegs tapped in the room next to the garage).
Here's my simple question that I can't seem to find an answer for.......
Once I get the engine warmed up/hot, how long do I typically have to set the lash 'hot' before I should look at running the engine again?
If I get it warm, and then there's some heat sink, will the engine stay 'hot' enough for an hour (or however long it's going to take to set the lash)??
Cheers!
