Max HP on cast 318 crank? #80761
06/28/08 12:38 AM
06/28/08 12:38 AM
Auburn WA
Dave_J Offline OP
Dave_J  Offline OP
Auburn WA
Got a 318. Have KB pistons that are lighter than stock. Also have Eagle SIR rods that are lighter. All together 1 whole piston,pin,keeper and rod weigh 237 grams less than the TRW 318 piston, pin and rod. This will be rebalenced with the cranks counterweight being lighted to match. So what is the safe limit for a cast crank? And humor me, I dont want a 340 or 360, a teen is a very good engine. DaveJ
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Max HP on cast 318 crank? [Re: Dave_J] #80762
06/28/08 08:48 AM
06/28/08 08:48 AM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
I would think 400HP would be no problem on a well balanced engine. Maybe someone else will chime in.
Re: Max HP on cast 318 crank? [Re: dmerc] #80763
06/28/08 09:08 AM
06/28/08 09:08 AM
NE Oklahoma
71valiant Offline
71valiant  Offline
NE Oklahoma
I always thought 318's had forged cranks. I'm probably wrong though.
Re: Max HP on cast 318 crank? [Re: 71valiant] #80764
06/28/08 09:23 AM
06/28/08 09:23 AM
ILL
mark7171 Offline
mark7171  Offline
ILL
i think your right. my 318 advertises a forged crank too, but also 9.0:1 compression.
max hp 400
max rpm 6300
Re: Max HP on cast 318 crank? [Re: 71valiant] #80765
06/28/08 09:28 AM
06/28/08 09:28 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
late 60's the 318 switched from forged to cast.
numerous guys running 550-600 HP w/cast 360 cranks, (think of the number of W2 headed 360's that have run over the years) the 318 has similar if not more journal overlap, so I'd say it should handle similar power levels.
2017 Grand Cherokee Overland
Re: Max HP on cast 318 crank? [Re: dmerc] #80766
06/28/08 09:30 AM
06/28/08 09:30 AM
Owego, NY
JBurch Offline
JBurch  Offline
Owego, NY
My guess would be 500 to 550, maybe more. That would be one of the last places I'd be worried about reliability in an engine build.
Re: Max HP on cast 318 crank? [Re: JBurch] #80767
06/28/08 09:41 AM
06/28/08 09:41 AM
ILL
mark7171 Offline
mark7171  Offline
ILL
you thinkin the rods might get bendy?
Re: Max HP on cast 318 crank? [Re: mark7171] #80768
06/28/08 02:45 PM
06/28/08 02:45 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I've never seen one break. Dave
Re: Max HP on cast 318 crank? [Re: quickd100] #80769
06/28/08 03:56 PM
06/28/08 03:56 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
As others have stated, the crank won't be the first thing to fail using stock parts, rods would top the list followed by blocks, which are good for 500-550hp before you'll see many issues.
Re: Max HP on cast 318 crank? [Re: ScottSmith_Harms] #80770
06/28/08 07:46 PM
06/28/08 07:46 PM
you might go to www.moparchat.com & scroll down to & click on circle track chat & check out Sanborns oiling mods that are in a sticky at the top.
Re: Max HP on cast 318 crank? [Re: RapidRobert] #80771
06/28/08 09:07 PM
06/28/08 09:07 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Ive been running 7800 RPM on my stock 360 crank for 8 years. Its a standard crank, Eagle H-beam rods, KB pistons, and the bottom end balanced. I recently pulled the motor apart to change the pistons when I added the Eddy heads, and inspected the bearings. They looked brand new. Plastigaged right on, and 80 psi cold, 55 hot at idle.
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Max HP on cast 318 crank? [Re: patrick] #80772
06/28/08 09:16 PM
06/28/08 09:16 PM
Pizza Bucket
snuggles Offline
snuggles  Offline
Pizza Bucket
I was thinking 71 was the last year for a forged crank in a 318
Re: Max HP on cast 318 crank? [Re: snuggles] #80773
06/28/08 09:56 PM
06/28/08 09:56 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Was told a while back the stock eliminator motors threw out the forged 340 crank in favor of the lighter cast 318 crank.
Last a season and throw it away.
Re: Max HP on cast 318 crank? [Re: theclutcher] #80774
06/28/08 10:45 PM
06/28/08 10:45 PM
GoDartGo Offline
GoDartGo  Offline
why not use a 273 forged crank? they are already
set up for a lighter piston.
Re: Max HP on cast 318 crank? [Re: GoDartGo] #80775
06/28/08 11:28 PM
06/28/08 11:28 PM
NY usa
540challenger Offline
NY usa
FOr a stick car the 273 crank is a good choice but if you have an auto cart the torque convertor hole is smaller then later la engines.
Re: Max HP on cast 318 crank? [Re: GoDartGo] #80776
06/28/08 11:59 PM
06/28/08 11:59 PM
Auburn WA
Dave_J Offline OP
Dave_J  Offline OP
Auburn WA
I have a 273 forged crank but they are not set up for light pistons. The small 273 piston is light but the piston pin is a huge hunk of steel. Ma Mopar used a Poly 318 crank to build the 273 but dident want to have to spend $$$ to rebalence it so they added weigh to the piston by making the pin so heavy, to equal a Poly 318's piston weight.
The block is a 78. Eagle SIR rods, not stock. We have done the drilling of the oil passages out, 1/2 inch for all the big ones to include the #5 main and oil pump, and 9/32 for the small ones from the mains to the lifter galery only. Will use a 8 qt pan with only 5 qts. Oil filter adapter PLATE has 4 more holes drilled inbetween. Windage tray with a small oil scraper. Oil cooler with 10 inch fan. Many more mods too. We were figuring around 450 HP. DaveJ
65 Formula S Cuda
