Max HP on cast 318 crank?
#80761
06/28/08 12:38 AM
06/28/08 12:38 AM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
Got a 318. Have KB pistons that are lighter than stock. Also have Eagle SIR rods that are lighter. All together 1 whole piston,pin,keeper and rod weigh 237 grams less than the TRW 318 piston, pin and rod. This will be rebalenced with the cranks counterweight being lighted to match. So what is the safe limit for a cast crank? And humor me, I dont want a 340 or 360, a teen is a very good engine. DaveJ
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
Re: Max HP on cast 318 crank?
[Re: 71valiant]
#80764
06/28/08 09:23 AM
06/28/08 09:23 AM
Posts: 1,261 ILL
mark7171
ILL
i think your right. my 318 advertises a forged crank too, but also 9.0:1 compression.
max hp 400 max rpm 6300
[Re: 71valiant]
#80765
06/28/08 09:28 AM
06/28/08 09:28 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
late 60's the 318 switched from forged to cast.
numerous guys running 550-600 HP w/cast 360 cranks, (think of the number of W2 headed 360's that have run over the years) the 318 has similar if not more journal overlap, so I'd say it should handle similar power levels.
[Re: ScottSmith_Harms]
#80770
06/28/08 07:46 PM
06/28/08 07:46 PM
RapidRobert
you might go to www.moparchat.com & scroll down to & click on circle track chat & check out Sanborns oiling mods that are in a sticky at the top.
[Re: RapidRobert]
#80771
06/28/08 09:07 PM
06/28/08 09:07 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Ive been running 7800 RPM on my stock 360 crank for 8 years. Its a standard crank, Eagle H-beam rods, KB pistons, and the bottom end balanced. I recently pulled the motor apart to change the pistons when I added the Eddy heads, and inspected the bearings. They looked brand new. Plastigaged right on, and 80 psi cold, 55 hot at idle.
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: patrick]
#80772
06/28/08 09:16 PM
06/28/08 09:16 PM
Posts: 8,964 Pizza Bucket
snuggles
Pizza Bucket
I was thinking 71 was the last year for a forged crank in a 318
[Re: GoDartGo]
#80775
06/28/08 11:28 PM
06/28/08 11:28 PM
Posts: 2,826 NY usa
540challenger
NY usa
why not use a 273 forged crank? they are already set up for a lighter piston.
FOr a stick car the 273 crank is a good choice but if you have an auto cart the torque convertor hole is smaller then later la engines.
[Re: GoDartGo]
#80776
06/28/08 11:59 PM
06/28/08 11:59 PM
Dave_J
Auburn WA
I have a 273 forged crank but they are not set up for light pistons. The small 273 piston is light but the piston pin is a huge hunk of steel. Ma Mopar used a Poly 318 crank to build the 273 but dident want to have to spend $$$ to rebalence it so they added weigh to the piston by making the pin so heavy, to equal a Poly 318's piston weight.
The block is a 78. Eagle SIR rods, not stock. We have done the drilling of the oil passages out, 1/2 inch for all the big ones to include the #5 main and oil pump, and 9/32 for the small ones from the mains to the lifter galery only. Will use a 8 qt pan with only 5 qts. Oil filter adapter PLATE has 4 more holes drilled inbetween. Windage tray with a small oil scraper. Oil cooler with 10 inch fan. Many more mods too. We were figuring around 450 HP. DaveJ
