How to seal oil filter adapter #80731
06/27/08 10:23 PM
06/27/08 10:23 PM
Kansas
racincuda Offline OP
Kansas
How to seal oil filter adapter ? Pump puts out 80 PSI at start up and while driveway tuning I noticed th oil puddle, now mor work Soo while cleaning the adapter I notice the silicone RTV comes off th gasket real easy Ok this isnt right and the 3M I used on the adapter side is lookin kinda rubber like not wat I wanted to see
So what are you Mopar Pro's using to seal items like this ?
Also hav a dripping oil pan gasket, new gasket no miles and looks & drips like 100 thousand
That means mor
My favorite sealants are failing me
Re: How to seal oil filter adapter [Re: racincuda] #80732
06/27/08 10:39 PM
06/27/08 10:39 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
A flat clean surface and a new gasket should cure your adapter leak. Oil pan leaks are normally caused because the lip of the pan is wavy or overtightened squeezing the gasket out. I use a dab of sealer in the corners only.
Re: How to seal oil filter adapter [Re: racincuda] #80733
06/27/08 10:42 PM
06/27/08 10:42 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
you can get a replacement kit from mopar performance for 35 dollars. Spend the money and get the new plate and gaskets. Just dont seal it with silicone.
Re: How to seal oil filter adapter [Re: Dart 340] #80734
06/27/08 10:49 PM
06/27/08 10:49 PM
Eastern Ohio
mopowergtx Offline
mopowergtx  Offline
Eastern Ohio
This topic just popped up the other day. Like was said here either get a new adapter or do what was recommended and what I did for mine take one hammer and place it of the center of the adapter plate and give a few good hard whacks with another hammer. Felpro makes an orignal type thick gasket which is readily available and with it in place set the adapter on the block and look to see if the center of the plate is not touching the block. If its not tighten it up and you'll be good to go. NO SILICONE NEEDED. If the center touches with the new gasket beat it some more or get the previously mentioned new plate.
Re: How to seal oil filter adapter [Re: Dart 340] #80735
06/27/08 10:57 PM
06/27/08 10:57 PM
Kansas
Kansas
Wat I want is a sealant that wont fall down on th job A new gasket is a start but it wont seal without some glue. I hav done it bfor but just dont remember wat I used
Is the memory the first to go, I dont remember
Re: How to seal oil filter adapter [Re: racincuda] #80736
06/27/08 11:00 PM
06/27/08 11:00 PM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Felpro makes a hi tack sealant that is pretty good, just a hard thing to remove.
Re: How to seal oil filter adapter [Re: racincuda] #80737
06/28/08 09:20 AM
06/28/08 09:20 AM
Yes it is among other things . I'd get a new plate,a new gasket set(3) pieces plus the thick fel pro one & substitute it in for the large round one,permatex #2 in the tube,clean everything perfect with small wire bristle brush. then comes then pan
Re: How to seal oil filter adapter [Re: RapidRobert] #80738
06/28/08 12:45 PM
06/28/08 12:45 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
DO NOT use a sealant. The factory didn't and you shouldn't either, especially a wholly inappropriate sealant like RTV.
Don't be the exception.
Re: How to seal oil filter adapter [Re: Supercuda] #80739
06/28/08 01:12 PM
06/28/08 01:12 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
for the oil pan, I used a one-peice oil pan gasket. I think it was a SCE brand. It is a rebber gasket with metal washers? around the bolt holes so you can't overtighten the gasket.
For the oil filter adaptor, if it is the stock steel plate, makes sure the outer diameter contache the block before the center. Do not use a gasket under the center part of the plate, The only gasket needed is the outer one.
Make sure all the old gasket material is removed. A stiff wire wheel on a drill, or dremel tool works. Install the new gasket dry or with a thin Hi-tac cement. My personal preference is Indian Head gasket shalic, but is is simular to the Permatex Hi-Tack, just do not use RTV.
I have not used the 90-degree adaptor, so if you are using one put that info in the post. Sorry, I can't help on that one.
Re: How to seal oil filter adapter [Re: 451Mopar] #80740
06/28/08 01:40 PM
06/28/08 01:40 PM
Kansas
Kansas
Yes this is for da 90 adapter and yes I hav all surfaces clean & dry
Looks like it's gonna be Indian head
? how long do I need to wait before firing engine
That's the Question of the day in my garage
Sce pan gasket sounds like a modern approach, bout time
Ok bac to
Re: How to seal oil filter adapter [Re: racincuda] #80741
06/28/08 02:18 PM
06/28/08 02:18 PM
md
mopars4ever Offline
mopars4ever  Offline
md
You shouldn`t need any sealer. I have two cars with the adapters and I have no leaks. Make sure that you snug the adapter down tight and make sure the bolt isn`t bottoming out. Get the gasket kit from mopar performance. It is only a few dollars IIRC. Mike
