Re: How to seal oil filter adapter
[Re: racincuda]
#80732
06/27/08 10:39 PM
06/27/08 10:39 PM
Posts: 32,934 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
A flat clean surface and a new gasket should cure your adapter leak. Oil pan leaks are normally caused because the lip of the pan is wavy or overtightened squeezing the gasket out. I use a dab of sealer in the corners only.
[Re: RapidRobert]
#80738
06/28/08 12:45 PM
06/28/08 12:45 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
DO NOT use a sealant. The factory didn't and you shouldn't either, especially a wholly inappropriate sealant like RTV.
[Re: Supercuda]
#80739
06/28/08 01:12 PM
06/28/08 01:12 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
for the oil pan, I used a one-peice oil pan gasket. I think it was a SCE brand. It is a rebber gasket with metal washers? around the bolt holes so you can't overtighten the gasket.
For the oil filter adaptor, if it is the stock steel plate, makes sure the outer diameter contache the block before the center. Do not use a gasket under the center part of the plate, The only gasket needed is the outer one.
Make sure all the old gasket material is removed. A stiff wire wheel on a drill, or dremel tool works. Install the new gasket dry or with a thin Hi-tac cement. My personal preference is Indian Head gasket shalic, but is is simular to the Permatex Hi-Tack, just do not use RTV.
I have not used the 90-degree adaptor, so if you are using one put that info in the post. Sorry, I can't help on that one.
[Re: 451Mopar]
#80740
06/28/08 01:40 PM
06/28/08 01:40 PM
Posts: 650 Kansas
racincuda
Kansas
Yes this is for da 90 adapter and yes I hav all surfaces clean & dry Looks like it's gonna be Indian head ? how long do I need to wait before firing engine That's the Question of the day in my garage Sce pan gasket sounds like a modern approach, bout time Ok bac to
