Brake Lines - Mild Steel or Stainless-What Do You Like? #80649
06/27/08 07:43 PM
06/27/08 07:43 PM
Seattle, WA
rss Offline OP
rss  Offline OP
Seattle, WA
While recently reading some old posts on brake fluid I noticed several people complain about having problems with brake fluid leaks after installing new stainless steel lines. I believe the theory was that because stainless is much harder than the standard mild steel lines that it was more difficult to get a good seal at the treaded fittings.
Anyone else have this problem?
What are your thoughts? Would you go stainless again or go back to the original mild steel lines?
Re: Brake Lines - Mild Steel or Stainless-What Do You Like? [Re: rss] #80650
06/27/08 07:47 PM
06/27/08 07:47 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
For a car that never sees road salt, go mild steel. They'll last the rest the life of car. If it is a winter beater, definitely stainless.
Re: Brake Lines - Mild Steel or Stainless-What Do You Like? [Re: rss] #80651
06/27/08 07:54 PM
06/27/08 07:54 PM
I used stainless on my RR resto without a problem. I wouldn't hesitate to use them again.
Re: Brake Lines - Mild Steel or Stainless-What Do You L #80652
06/27/08 08:07 PM
06/27/08 08:07 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I agree but there is a better chance of initial leak as SS just isn't as malleable as MS. If you cut and flare your own it's even tougher. Still, well worth the effort for any application. -Bob
Re: Brake Lines - Mild Steel or Stainless-What Do You Like? [Re: rss] #80653
06/27/08 08:21 PM
06/27/08 08:21 PM
Eastern North Carolina
cyphre666 Offline
cyphre666  Offline
Go S.S. it's a once and done deal
Re: Brake Lines - Mild Steel or Stainless-What Do You Like? [Re: cyphre666] #80654
06/27/08 08:35 PM
06/27/08 08:35 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
in-line stainless steel lines here, zero sealing problems. Fit great!
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Brake Lines - Mild Steel or Stainless-What Do You Like? [Re: GoodysGotaCuda] #80655
06/27/08 08:43 PM
06/27/08 08:43 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Mild steel 4 me, I do clear coat them though.
All the cars I did for guys at my old shop wanted stainless and had plenty of problems with leaks and a bunch of waisted time and their money working them out.
Re: Brake Lines - Mild Steel or Stainless-What Do You Like? [Re: rrunner] #80656
06/27/08 09:09 PM
06/27/08 09:09 PM
IN
ahy Offline
ahy  Offline
IN
Mild steel for me. The original steel brake lines on my car were in pretty good shape after 35 years and I'm not driving my car through salt.
Mild steel is easier to flare, easier to bend and easier to seal. And less costly.
Re: Brake Lines - Mild Steel or Stainless-What Do You Like? [Re: ahy] #80657
06/27/08 09:41 PM
06/27/08 09:41 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
Stainless here
Re: Brake Lines - Mild Steel or Stainless-What Do You Like? [Re: Michael] #80658
06/27/08 09:50 PM
06/27/08 09:50 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
Stainless, I had a leak and it required a little more work on the installer part to get it right, that's me can't blame the part for my not double checking fit first. I'd use them again.
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: Brake Lines - Mild Steel or Stainless-What Do You L [Re: R70RUNNER] #80659
06/27/08 09:57 PM
06/27/08 09:57 PM
Nanuet, NY
3
383BeepBeep Offline
383BeepBeep  Offline
Nanuet, NY
Done three cars all stainless. Only problem I had was with an adjustable prop valve. I had to cut and reflare a line. Stainless is some tuff stuff to flare. No cheap flare tool will flare it. Heads up. Other then that zero problems. BTW I used Inline Tube lines. Very good fit, and no sealing issues. Done it on a 69 Bird, 71 Scamp, and a 49 Pontiac.
1969 Plymouth Roadrunner - 383- 4 Speed - Dana 60 4:10
Re: Brake Lines - Mild Steel or Stainless-What Do You Like? [Re: rss] #80660
06/27/08 11:06 PM
06/27/08 11:06 PM
Missouri, U.S.A.
JSSuperbee Offline
JSSuperbee  Offline
Missouri, U.S.A.
I'll never use stainless again. Too many leaks. Happened on 2 cars. From now on I'll use mild steel and clear coat them. Stainless is nothing but trouble.
James Stinebaker
Re: Brake Lines - Mild Steel or Stainless-What Do You L [Re: JSSuperbee] #80661
06/28/08 01:27 AM
06/28/08 01:27 AM
Seattle, WA
rss Offline OP
rss  Offline OP
Seattle, WA
Glad to see that there is a total lack of agreement on yet another old mopar issue. Almost as much disagreement as the DOT 4 vs. DOT 5 brake fluid posts I was reading last night
Seems like if you purchase the pre-bent lines the cost difference for stainless is pretty much nil, especially if you consider all the hassle of trying to spray clear on the mild steel lines. The full line sets I saw were only about $20 more for stainless. Certainly not worth the hassle of buying and spraying clear in my book.
Still, if all the leak horror stories are true, I might still go mild steel. I just wouldn't bother painting it.
Thanks for all the input guys
Re: Brake Lines - Mild Steel or Stainless-What Do You L [Re: rss] #80662
06/28/08 12:03 PM
06/28/08 12:03 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Here, I'll add another for stainless. I did my car completely with stainless. No issues with leaks. BTW, I use DOT 5
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Brake Lines - Mild Steel or Stainless-What Do You L [Re: RoadRunner] #80663
06/28/08 01:37 PM
06/28/08 01:37 PM
SW MO
closer9 Offline
closer9  Offline
SW MO
Another for stainless. I went with prebent SS on mine, and no leak issues.
rusty steel was never even considered. Clear coat won't last forever...
Daily:
'19 Frontier 4WD
Belle:
'67 Belvedere Convertible, 318/727 in Go ManGo!
Other:
'64 C10, 283/3 on the tree
Re: Brake Lines - Mild Steel or Stainless-What Do You L [Re: closer9] #80664
06/28/08 02:32 PM
06/28/08 02:32 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Not only won't the clear last forever it does nothing to protect the inside of the tube where rust ALWAYS develops with glycol based fluids(Dot 3,4). -Bob
Re: Brake Lines - Mild Steel or Stainless-What Do You L [Re: BobR] #80665
06/28/08 02:49 PM
06/28/08 02:49 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
I used mild steel and dot5
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Brake Lines - Mild Steel or Stainless-What Do You L [Re: 340SIX] #80666
06/28/08 03:45 PM
06/28/08 03:45 PM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
Me too
Re: Brake Lines - Mild Steel or Stainless-What Do You L [Re: gygeneral] #80667
06/28/08 05:26 PM
06/28/08 05:26 PM
west kentucky
gomangoRTSE Offline
gomangoRTSE  Offline
west kentucky
Step it up the ultimate level. If your car is painted underneath or I suppose even if it isnt, polish your stainless lines and it will knock the crowd out.
Re: Brake Lines - Mild Steel or Stainless-What Do You L [Re: BobR] #80668
06/29/08 01:02 AM
06/29/08 01:02 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
rusty steel was never even considered. Clear coat won't last forever... it does nothing to protect the inside of the tube where rust ALWAYS develops with glycol based fluids(Dot 3,4). -Bob
That is a pretty strong statement. Would a caliper rust/up/lock way before the line would rust out? most mild steel lines are "terne" plated? and salt is the biggest hazard from the outside? I do like SS brake lines, but a nice leak proof douple inverted flare is no for the timid.
