Re: Brake Lines - Mild Steel or Stainless-What Do You Like?
[Re: rss]
#80650
06/27/08 07:47 PM
06/27/08 07:47 PM
Posts: 4,404 Michigan
MarkZ
Worthy
Worthy
For a car that never sees road salt, go mild steel. They'll last the rest the life of car. If it is a winter beater, definitely stainless.
[Re: rss]
#80651
06/27/08 07:54 PM
06/27/08 07:54 PM
I used stainless on my RR resto without a problem. I wouldn't hesitate to use them again.
#80652
06/27/08 08:07 PM
06/27/08 08:07 PM
Posts: 8,165 Left Coast
BobR
Left Coast
I agree but there is a better chance of initial leak as SS just isn't as malleable as MS. If you cut and flare your own it's even tougher. Still, well worth the effort for any application. -Bob
[Re: Michael]
#80658
06/27/08 09:50 PM
06/27/08 09:50 PM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
Stainless, I had a leak and it required a little more work on the installer part to get it right, that's me can't blame the part for my not double checking fit first. I'd use them again.
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: rss]
#80660
06/27/08 11:06 PM
06/27/08 11:06 PM
Posts: 328 Missouri, U.S.A.
JSSuperbee
Missouri, U.S.A.
I'll never use stainless again. Too many leaks. Happened on 2 cars. From now on I'll use mild steel and clear coat them. Stainless is nothing but trouble.
James Stinebaker
[Re: JSSuperbee]
#80661
06/28/08 01:27 AM
06/28/08 01:27 AM
Posts: 902 Seattle, WA
rss
Seattle, WA
Glad to see that there is a total lack of agreement on yet another old mopar issue. Almost as much disagreement as the DOT 4 vs. DOT 5 brake fluid posts I was reading last night Seems like if you purchase the pre-bent lines the cost difference for stainless is pretty much nil, especially if you consider all the hassle of trying to spray clear on the mild steel lines. The full line sets I saw were only about $20 more for stainless. Certainly not worth the hassle of buying and spraying clear in my book. Still, if all the leak horror stories are true, I might still go mild steel. I just wouldn't bother painting it. Thanks for all the input guys
[Re: RoadRunner]
#80663
06/28/08 01:37 PM
06/28/08 01:37 PM
Posts: 2,190 SW MO
closer9
SW MO
Another for stainless. I went with prebent SS on mine, and no leak issues.
rusty steel was never even considered. Clear coat won't last forever...
Daily: '19 Frontier 4WD Belle: '67 Belvedere Convertible, 318/727 in Go ManGo! Other: '64 C10, 283/3 on the tree
[Re: closer9]
#80664
06/28/08 02:32 PM
06/28/08 02:32 PM
BobR
Left Coast
Not only won't the clear last forever it does nothing to protect the inside of the tube where rust ALWAYS develops with glycol based fluids(Dot 3,4). -Bob
[Re: BobR]
#80665
06/28/08 02:49 PM
06/28/08 02:49 PM
Posts: 28,596 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
I used mild steel and dot5
[Re: 340SIX]
#80666
06/28/08 03:45 PM
06/28/08 03:45 PM
Posts: 1,052 Ont, Canada
gygeneral
Ont, Canada
Me too
