Page 11 of 19 1 2 9 10 11 12 13 18 19
Re: 514 on the dyno [Re: Adrielp] #804372
11/07/11 05:46 PM
11/07/11 05:46 PM
AndyF Online content OP
AndyF  Online Content OP
Peak power is around 6700 rpm with the 266/272 cam.
Re: 514 on the dyno [Re: Adrielp] #804373
11/23/11 02:15 AM
11/23/11 02:15 AM
Crane recommended this 280/286 cam with .452 lobe lift. It is quite a bit larger than my existing 266/272 cam so we'll see what happens with the power curve.
I'm still waiting for a couple of parts to show up and then I'll get the engine back on the dyno for some more testing.
Re: 514 on the dyno [Re: WheelsUp73] #804374
11/23/11 02:42 AM
11/23/11 02:42 AM
Let's stay on topic here..
WHY
Re: 514 on the dyno [Re: Cab_Burge] #804375
11/24/11 12:20 PM
11/24/11 12:20 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
It'll be intersting to see the cam comparison, but for it to be accurate you'd have to run it with the same intake you ran the last one with first, not the Wilson-ized one, is that right?
I would think/predict that the flow limitations of the stock height/short turn compromised EZ exhaust port are going to show up sooner or later...the bigger cam will certainly raise the torque peak RPM but the HP curve is likely not going to keep rising quite as dramatically/proportionally.
It would be great and very much appreciated (especially for us analytical 'cause and effect' type tech junkies/tuner types) to see the dyno charts on these pulls if possible, Andy!! Thanks in advance!!
BTW, I was thinking about buying that same MJ grind for my 517, let me know if you want to sell it! Also, how much did Wilson charge for all that work?
WIZE
In Car:
Re: 514 on the dyno [Re: Streetwize] #804376
11/24/11 01:39 PM
11/24/11 01:39 PM
I'd be willing to sell that Jones cam, shoot me a PM. It was a really stout cam with my setup.
Wilson charges about $1100 for their competition port when welding is required.
Re: 514 on the dyno [Re: AndyF] #804377
11/25/11 02:23 PM
11/25/11 02:23 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
PM sent!!
Thanks!
Bobby
WIZE
In Car:
Re: 514 on the dyno [Re: AndyF] #804378
11/29/11 02:27 AM
11/29/11 02:27 AM
I had BLP build me a 2 circuit 1250 carb. It should work well with the Wilson ported intake.
Re: 514 on the dyno [Re: AndyF] #804379
11/29/11 03:26 PM
11/29/11 03:26 PM
If you look close you can see two jets that BLP puts in the top of the carb near the carb stud. Those are for idle air. It is easier to change jets up there than to flip the carb over and drill the throttle plates. Clever idea that makes an engine easier to tune.
Re: 514 on the dyno [Re: AndyF] #804380
11/29/11 11:20 PM
11/29/11 11:20 PM
gregsdart Offline
gregsdart  Offline
Sure would have been nice when I was tuning a tunnelram. I think I only had to pull the carbs three times!
Re: 514 on the dyno [Re: AndyF] #804381
01/26/12 11:43 PM
01/26/12 11:43 PM
New dry sump pan showed up the other day. I had Charlie build me a big pan. We'll see if the exra volume helps to make some power. This pan is really big. It has a 4 inch kickout and a deep belly section.
Re: 514 on the dyno [Re: AndyF] #804382
01/27/12 12:38 AM
01/27/12 12:38 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
NICE.......
Re: 514 on the dyno [Re: 70blackfish] #804383
01/28/12 01:08 AM
01/28/12 01:08 AM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
VERY impressive,Andy! Wish my little ole' 440 could break ANYONE'S dyno! Can't wait to get it back on Jake's dyno this Spring/Summer...after freshening up the motor,and bolting up the MCH cnc'd Eddy's...with additional compression..10:1-11:1!
Re: 514 on the dyno [Re: AndyF] #804384
02/20/12 03:13 PM
02/20/12 03:13 PM
Putting the pan on the engine shows how large it is.
Re: 514 on the dyno [Re: AndyF] #804385
02/20/12 03:14 PM
02/20/12 03:14 PM
Window side.
Re: 514 on the dyno [Re: AndyF] #804386
03/07/12 02:22 AM
03/07/12 02:22 AM
New pistons are here so now I have everything necessary to redo the shortblock. These pistons push the compression up to a little more than 15:1
Re: 514 on the dyno [Re: AndyF] #804387
12/08/12 07:28 PM
12/08/12 07:28 PM
I haven't worked on this project for awhile now. I did get a ModMan intake from Indy so I'll probably try that next time we go to the dyno. That might be interesting.
I loaned my Wilson ported Super Victor to the guys at Hughes Engines so they could do some dyno testing. I'm looking forward to how those tests go. Once the intake comes back I'll get this 514 back on the dyno. We'll see if the higher compression, Crane cam and the bigger oil pan make any difference.
Re: 514 on the dyno [Re: AndyF] #804388
12/08/12 09:07 PM
12/08/12 09:07 PM
Delray beach, Florida
P
Performance Only Offline
P
Is the big pan going on right away, and will you swap pans at some point to see what difference it makes?
machine shop owner and engine builder
Re: 514 on the dyno [Re: Performance Only] #804389
12/27/12 07:11 PM
12/27/12 07:11 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
AndyF,What percentage of load are you using on your dyno pulls?
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: 514 on the dyno [Re: MRMOPAR622] #804390
12/27/12 11:31 PM
12/27/12 11:31 PM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
Hi Andy, I took the liberty of plugging in the numbers on the new combo, I use engine analyzer pro and with 15:1 compression, the ez heads, 7.1 rods, new cam, ported intake and 1200 cfm carb, the 514 made 918hp at 6600rpm and 802ftlb at 5200.
I ran the water temp at 140f
Re: 514 on the dyno [Re: Performance Only] #804391
12/28/12 01:18 PM
12/28/12 01:18 PM
That would be a fun test to run but I don't have the time these days to do that type of testing. I'll be lucky to even get some dyno pulls on the new engine combo much less do any back to back testing.
