Re: 514 on the dyno
[Re: Cab_Burge]
#804375
11/24/11 12:20 PM
11/24/11 12:20 PM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
It'll be intersting to see the cam comparison, but for it to be accurate you'd have to run it with the same intake you ran the last one with first, not the Wilson-ized one, is that right? I would think/predict that the flow limitations of the stock height/short turn compromised EZ exhaust port are going to show up sooner or later...the bigger cam will certainly raise the torque peak RPM but the HP curve is likely not going to keep rising quite as dramatically/proportionally. It would be great and very much appreciated (especially for us analytical 'cause and effect' type tech junkies/tuner types) to see the dyno charts on these pulls if possible, Andy!! Thanks in advance!! BTW, I was thinking about buying that same MJ grind for my 517, let me know if you want to sell it! Also, how much did Wilson charge for all that work?
Re: 514 on the dyno
[Re: AndyF]
#804385
02/20/12 03:14 PM
02/20/12 03:14 PM
Posts: 31,050 Oregon
AndyF
Re: 514 on the dyno
[Re: Performance Only]
#804389
12/27/12 07:11 PM
12/27/12 07:11 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
AndyF,What percentage of load are you using on your dyno pulls?
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
Re: 514 on the dyno
[Re: MRMOPAR622]
#804390
12/27/12 11:31 PM
12/27/12 11:31 PM
Posts: 1,260 Las Vegas NV
moparmanjames
Las Vegas NV
Hi Andy, I took the liberty of plugging in the numbers on the new combo, I use engine analyzer pro and with 15:1 compression, the ez heads, 7.1 rods, new cam, ported intake and 1200 cfm carb, the 514 made 918hp at 6600rpm and 802ftlb at 5200.
I ran the water temp at 140f
Re: 514 on the dyno
#804391
12/28/12 01:18 PM
12/28/12 01:18 PM
AndyF
New dry sump pan showed up the other day. I had Charlie build me a big pan. We'll see if the exra volume helps to make some power. This pan is really big. It has a 4 inch kickout and a deep belly section.
Is the big pan going on right away, and will you swap pans at some point to see what difference it makes?
That would be a fun test to run but I don't have the time these days to do that type of testing. I'll be lucky to even get some dyno pulls on the new engine combo much less do any back to back testing.
