Page 4 of 19 1 2 3 4 5 6 18 19
Re: 514 on the dyno [Re: Big Squeeze] #804232
02/22/11 10:59 PM
02/22/11 10:59 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I see them. It is a little more work to post a dyno sheet then it is to just reply. But, you could of been replied to at least. IMO
Re: 514 on the dyno [Re: Dart of Denmark] #804233
02/22/11 11:53 PM
02/22/11 11:53 PM
Laredo, Texas USA
hugo Offline
hugo  Offline
Laredo, Texas USA
Have you tried it with a vaccum pump?
Re: 514 on the dyno [Re: Big Squeeze] #804234
02/23/11 11:32 AM
02/23/11 11:32 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
you are ignoring this user
kidding ...
Re: 514 on the dyno [Re: JohnRR] #804235
02/23/11 03:22 PM
02/23/11 03:22 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
kidding ...
That's what I was starting to think......
If you can't handle the truth, you're living a lie.......
Re: 514 on the dyno [Re: Sport440] #804236
02/25/11 11:35 PM
02/25/11 11:35 PM
AndyF Offline OP
AndyF  Offline OP
I look forward to the DP results. Thanks for sharing.
Let's just say it wasn't a good idea to run the Indy DP on this motor! We lost 100 hp and the EGT readings went wacky. Now I need to pull the plugs and check for damage. I tried it, but in hindsight I should've just left it on the shelf and stuck with the race intakes.
Re: 514 on the dyno [Re: AndyF] #804237
02/25/11 11:46 PM
02/25/11 11:46 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Where's the "holding my breath until I'm blue waiting on a dyno sheet Instant Graemlin"???
Re: 514 on the dyno [Re: Big Squeeze] #804238
02/25/11 11:49 PM
02/25/11 11:49 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
get in line!
I asked about the oil pan hitting the auto cross car's k frame a few times and got ignored as well - so take a number!!!
Re: 514 on the dyno [Re: AndyF] #804239
02/26/11 02:35 AM
02/26/11 02:35 AM
AndyF Offline OP
AndyF  Offline OP
Moparts member Drag Stripper brought over his 337 intake so we bolted that on and make a couple of pulls. It made a little over 800 hp, right in line with the SV, 440-2 and 440-3X. Basically all four of those intakes made the same power. They might not go down the track the same, but on the dyno there wasn't any real difference between them.
Re: 514 on the dyno [Re: Chuck@Best_Machine] #804240
02/26/11 02:40 AM
02/26/11 02:40 AM
AndyF Offline OP
AndyF  Offline OP
I'm running a dry sump on this motor. I really like the dry sump setup. It is so much easier to dial in a dry sump and the engine oiling is a lot better. Hate to go back to a wet sump design after working with a dry sump.
Andy, why are you running breathers ?
Chuck, I fabricated some adapters so I could run a Moroso vacuum relief valve as well as a vacuum gauge in the other valve cover. We made a bunch of dyno pulls with this setup and didn't see any power difference or any vacuum in the valve covers. We did see more oil leaks though so I'm going to go back to the breathers. My guess is that this little 3 stage dry sump pump just doesn't have the beans to pull a vacuum on this motor. I'll probably step up to a new 5 stage pump later this year so then I'll run the experiment again.
Re: 514 on the dyno [Re: AndyF] #804241
02/26/11 08:36 AM
02/26/11 08:36 AM
Delray beach, Florida
P
Performance Only Offline
P
how much air is this combo using at peak torque and horsepower.
machine shop owner and engine builder
Re: 514 on the dyno [Re: AndyF] #804242
02/26/11 10:00 AM
02/26/11 10:00 AM
NC
440Jim Offline
440Jim  Offline
NC
So, Andy. Do I have this right?
Can you complete the comparison?
Super Victor: 715 ft-lbs at 5500 and 830 hp at 6700 rpm.
Indy 440-3X: 715 ft-lbs at 5500 and 816 hp at 6700 rpm.
Indy 440-2_: with 4500 adapter
Mopar 337__: 800+ hp
Indy 440-2D: 7xx? hp (Dual plane port matched to Max Wedge)
514 CID
Mopar block with 4.440 bore and 4.150 stroke.
Indy MW EZ heads CNC ported by Modern Cyl Head, about 360 cfm.
Jesel rocker arms, 1.85 I and 1.70 E.
Solid roller cam with 266/272 duration.
Flat top pistons, gas ported
Compression around 12.4
Dry sump oil system
1150 cfm Holley Ultra Dominator
Headers: 2" dia x 32 length x 3.5 collector dia
Re: 514 on the dyno [Re: 440Jim] #804243
02/26/11 10:48 AM
02/26/11 10:48 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Great Post Andy, I was gonna ask if you wanted me to ship you my 337, I'm glad you found one. was the 337 OOTB or ported? As I mentioned in another post the 'as delivered' 337 ports are only about 1/2 way between a 906 and a real Maxie, the 337 does have excellent taper from the plenum as delived though.
Please reiterate how much you felt the top-line Jesel valve gear/timing belt and dry sump may have contributed to the overall performance. I'm thinking somewhere in the area of 50-60 HP @ 6000RPM compared to a conventional wet sump/chain 'flexi-pedestal' system.
I would say OOTB the Indy 2D would definately be a mis match, but when you port it right that will narrow the performance gap quite a bit, and of course running the same Dommy with an open 4150/4500 adapter on a true dual plane would probably Skew the A/F and EGT's quite a bit....even still I'll bet the 2D torque (with the optimum jetting) between 3500 and 5000 was pretty insane.
If those EZ-1's worked that well with that 'not so great' exhaust port, I can only imagine what a full tilt -1 or equivalently MW intake ported SR would have done
I'm probably not the only one who would really appreciate seeing the corresponding Dyno powerband graphs; peak to peak numbers are cool and all but it's really way less than 1/2 the 'big picture' of how components perform against one another.
Looks like the 337 is the only viable "fit's under the hood" big single....you've inspired me to start porting it to get it to full MW size cause I think we can make up that ~15 horse deficit pretty quickly. It's even more impressive knowing it's a 4150 base which you would think puts it at a severe disadvantage to the 4500 flange competition.
WIZE
In Car:
Re: 514 on the dyno [Re: DJVCuda] #804244
02/26/11 11:55 AM
02/26/11 11:55 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
get in line!
At least now I don't feel so bad.....
I hate to be the turd in the punch bowl, but without dyno sheets so we can look as BSFC numbers and the correction factor (or MPH numbers at a certain weight for a car that's actually raced), this whole thread and these numbers are just a bunch of hot air...... (but they do make great magazine articles.... )
Am I the only one that thinks Andy is ONE BAD-AZZ engine builder.....or that dyno is about 100HP HAPPY??????........ ......It'd be interesting to actually see some real proof.....
Re: 514 on the dyno [Re: Big Squeeze] #804245
02/26/11 12:35 PM
02/26/11 12:35 PM
NC
440Jim Offline
440Jim  Offline
NC
Wayne,
I take all dyno numbers with a grain of salt. I don't know how 800 hp on that dyno compares to another dyno. But I do like the back to back comparisons of intake changes, etc. But the dyno sheets with other measurements (air flow, fuel flow, BSFC, water temp, oil temp, etc.) would add value.
Re: 514 on the dyno [Re: 440Jim] #804246
02/26/11 01:16 PM
02/26/11 01:16 PM
gregsdart Offline
gregsdart  Offline
Looks to me like the starting point was in line with what should be expected power wise. I'm betting the Hp gains shown so far are accurate, and the motor will run the ET numbers to back it up.
Re: 514 on the dyno [Re: gregsdart] #804247
02/26/11 01:31 PM
02/26/11 01:31 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Again, I think Andy eluded to the Dry-sump and jesel valvetrain moving the HP up considerably, I've noticed my valvetrain is a lot more stable at 6500+ using the 1 piece Billet Block rocker stands instead of the cast-in pedestals, I think that could be 15-20hp right there alone, let alone a full-tilt State of the art Jesel system
Not overstating the Dyno sheet "issue" but in terms of printing out the HP/TQ curves, one could naturally ask "why not" post them??
WIZE
In Car:
Re: 514 on the dyno [Re: Streetwize] #804248
02/26/11 02:44 PM
02/26/11 02:44 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
HP and TQ numbers seem perfectly reasonable to me from a professionally built engine.
Re: 514 on the dyno [Re: 440Jim] #804249
02/26/11 03:13 PM
02/26/11 03:13 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Wayne,
I'm the same way about dyno numbers, that's why I'd like to at least see the sheet and/or MPH numbers at the track....and I also like to see back to back tests.......but just throwing numbers out there doesn't do much good.....I'm assuming there are motors out there that have been on that dyno with comparable numbers that have actually been raced, so it'd be interesting to find out what they run???
I've asked three times about the dyno sheet and haven't received any kind of reply...... just seems a little fishy....
Re: 514 on the dyno [Re: 440Jim] #804250
02/26/11 03:21 PM
02/26/11 03:21 PM
AndyF Offline OP
AndyF  Offline OP
514 CID
Dry sump oil system
Yep, that is basically correct. The 337, SV and 440-2 were all right at 830 hp. The Indy DP dropped to 710 hp.
The 337 was gasket matched and blended on the runners. The plenum was opened up to a cut down 4500 adapter. Drag Stripper has modified that intake to work with his hood scoop clearance so he had a custom adapter on it.
I wanted to run my B1 intake but the adapters I have for it didn't fit quite right so we couldn't make any pulls.
I need to figure out what to do with the crankcase vacuum. I'm pretty sure I can pick up another 20-30 hp with a bigger dry sump pump and/or a vacuum pump. Do both upgrades will cost me about $2000 so that is a big chunk of change. I'll have to make a few calls to see what people recommend.
Re: 514 on the dyno [Re: 440Jim] #804251
02/26/11 03:36 PM
02/26/11 03:36 PM
AndyF Offline OP
AndyF  Offline OP
BSFC is about .420 at peak HP for all of the intakes. Seems a little low but I haven't really spent much time thinking about it. It is easy for those little sensors to get messed up and it is expensive to calibrate them so I don't really worry about it much. I don't worry about fuel economy with this engine, we just fill the tank up with race gas when it gets low.
I haven't played with coolant temp yet. I know that other engine builders drop the coolant temp on the dyno to add power. So far I have just been runnning a conservative temp in the cooling tower. There is a chunk of power just sitting on the table there but I'm more interested in exploring the oil pan/pump/vacuum issue at the moment. Running the engine cold adds risk which I don't want to take right now.
