275's all around on a B-body ?
#80365
06/27/08 12:43 AM
06/27/08 12:43 AM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
I need some outside the box type thinking right now. I want to put the same size tires all around on my Roadrunner. I've seen Todd (blackwidow69) manage to squeeze 275's in on the front of his 69 Roadrunner. With 255's on 15x7 steelies (4 inch backspacing, right ?) I have rubbing at the rear of the front frame rail. In it's defense, that wheel is not the right size for even a 255 and the sidewall bulge is significant. With the right backspacing and right width wheel, I don't think I will have the same issue even with a 275 on a 9.5" wheel. What backspacing would you use to get a 9.5" wheel onto the front of a 68 B-body ?
Re: 275's all around on a B-body ?
[Re: AlexP]
#80367
06/27/08 03:50 AM
06/27/08 03:50 AM
Posts: 27,467 So Cal
autoxcuda
So Cal
What diameter rims are you looking at?
What is Todd's combo? Just copy it.
If 17" I'd go 5.25 on a 9.5 width rim with a 275/40/17 tire. That will probably rub the inner fender at max turning, but won't rub the outside. You might be able to run a little less backspacing on a B-body. But you could always add a good .25" spacer.
[Re: AlexP]
#80371
06/27/08 02:36 PM
06/27/08 02:36 PM
autoxcuda
So Cal
The tech I spoke with took down my current numbers and suggested that I buy a 17x9.5" in a 5.5" backspacing, mount it up without tires and if it doesn't fit I can return it and try a different size.
Do you have flat type upper ball joints or the domed type?
[Re: Mr.Yuck]
#80375
06/27/08 03:45 PM
06/27/08 03:45 PM
AlexP
Houston, Tx
That would look silly. the car would look like a 4WD vehicle.
No, not really.
[Re: topside]
#80378
06/27/08 11:11 PM
06/27/08 11:11 PM
Posts: 1,404 northeast ohio
hulmule
northeast ohio
I ran 275 60 15 on cop rims all the way around. looked like a old nascar or moon shine runner. I did notice that a little paint was rubbed of on the front frame rails. never heard it but it must have happen. If you want a picture send me a email address cause this site i cant seem to post any oictures . to big of a file. phil
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
[Re: hulmule]
#80379
06/27/08 11:34 PM
06/27/08 11:34 PM
w/ some spacers and airshocks lol you can run these fatties in the rear. no wheel well modification. Special order Pirelli P-zero street tires.
I'm going to ditch these and go w/ magnum 500's though.
[Re: AlexP]
#80381
06/28/08 02:42 AM
06/28/08 02:42 AM
17"/9"/4.5 backspace 275/55/17in back and 245/45/17 up front with rear sway bar no rubbing at all but no room for bigger tire terry
#80382
06/28/08 09:25 AM
06/28/08 09:25 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
a board member had '01-04 mustang 17x8 rims on his '69 RR using 3/4" thick bolt on spacers (makes for 5" effective backspace) all the way around and 255/50R17 BF goodrich KDWS's and they fit fine. I have the same setup on my 5th ave
