275's all around on a B-body ? #80365
06/27/08 12:43 AM
06/27/08 12:43 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I need some outside the box type thinking right now.
I want to put the same size tires all around on my Roadrunner. I've seen Todd (blackwidow69) manage to squeeze 275's in on the front of his 69 Roadrunner.
With 255's on 15x7 steelies (4 inch backspacing, right ?) I have rubbing at the rear of the front frame rail. In it's defense, that wheel is not the right size for even a 255 and the sidewall bulge is significant. With the right backspacing and right width wheel, I don't think I will have the same issue even with a 275 on a 9.5" wheel.
What backspacing would you use to get a 9.5" wheel onto the front of a 68 B-body ?
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: 275's all around on a B-body ? [Re: AlexP] #80366
06/27/08 03:31 AM
06/27/08 03:31 AM
IN
polaraholic Offline
polaraholic  Offline
IN
Sorry I can't anawer that but is that sway bar in the pic hooked up right? Looks like it is upside down.
Re: 275's all around on a B-body ? [Re: AlexP] #80367
06/27/08 03:50 AM
06/27/08 03:50 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
What diameter rims are you looking at?
What is Todd's combo? Just copy it.
If 17" I'd go 5.25 on a 9.5 width rim with a 275/40/17 tire. That will probably rub the inner fender at max turning, but won't rub the outside. You might be able to run a little less backspacing on a B-body. But you could always add a good .25" spacer.
Re: 275's all around on a B-body ? [Re: polaraholic] #80368
06/27/08 05:49 AM
06/27/08 05:49 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
, but performance wise, it would not matter
Re: 275's all around on a B-body ? [Re: jcc] #80369
06/27/08 02:04 PM
06/27/08 02:04 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
The tech I spoke with took down my current numbers and suggested that I buy a 17x9.5" in a 5.5" backspacing, mount it up without tires and if it doesn't fit I can return it and try a different size.
Re: 275's all around on a B-body ? [Re: AlexP] #80370
06/27/08 02:24 PM
06/27/08 02:24 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Also, just for giggles...What backspacing would it take to get a 315 on the rear ? I won't modify, so if it physically fit I will just do 275 rears and call it a day.
Re: 275's all around on a B-body ? [Re: AlexP] #80371
06/27/08 02:36 PM
06/27/08 02:36 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Do you have flat type upper ball joints or the domed type?
Re: 275's all around on a B-body ? [Re: autoxcuda] #80372
06/27/08 02:59 PM
06/27/08 02:59 PM
Hudson Mass
67Mopar Offline
67Mopar  Offline
Hudson Mass
275-15 is the limit, may have to stiffen up the rear suspension if you are getting rubbing next stop tubs. I think there is room on the front, but have only tried with my old 67 plymouth I like the 4 all the same look as well and plan on doing that with my new toy Scamp
Re: 275's all around on a B-body ? [Re: autoxcuda] #80373
06/27/08 03:12 PM
06/27/08 03:12 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I have the flat topped Moog K772 joints in my tubular UCA's.
Re: 275's all around on a B-body ? [Re: AlexP] #80374
06/27/08 03:40 PM
06/27/08 03:40 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
That would look silly. the car would look like a 4WD vehicle. And that sway bar is on upside down
Re: 275's all around on a B-body ? [Re: Mr.Yuck] #80375
06/27/08 03:45 PM
06/27/08 03:45 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
No, not really.
Re: 275's all around on a B-body ? [Re: AlexP] #80376
06/27/08 08:25 PM
06/27/08 08:25 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
With the right stance, it would look vintage nascar all day long. I'd rather see something like a 275/50-17 on all four, though, but I'm apparently funny that way...
Clair
Re: 275's all around on a B-body ? [Re: Clair_Davis] #80377
06/27/08 10:56 PM
06/27/08 10:56 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Vintage NASCAR would be 10x15 wheels with about a 70-series profile tire with 10" of tread width.
As for the 17" setup, I can't help there, but I've seen a 305/50R15 tire in a stock-height '69 Roadrunner and it cleared fine. The rims appeared to be 9" or 10" wide; they looked wider than the 8x15s (& 295/50R15s) on my '68.
Re: 275's all around on a B-body ? [Re: topside] #80378
06/27/08 11:11 PM
06/27/08 11:11 PM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
I ran 275 60 15 on cop rims all the way around. looked like a old nascar or moon shine runner. I did notice that a little paint was rubbed of on the front frame rails. never heard it but it must have happen. If you want a picture send me a email address cause this site i cant seem to post any oictures . to big of a file. phil
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: 275's all around on a B-body ? [Re: hulmule] #80379
06/27/08 11:34 PM
06/27/08 11:34 PM
w/ some spacers and airshocks lol you can run these fatties in the rear. no wheel well modification. Special order Pirelli P-zero street tires.
I'm going to ditch these and go w/ magnum 500's though.
Re: 275's all around on a B-body ? [Re: Mr.Yuck] #80380
06/27/08 11:35 PM
06/27/08 11:35 PM
east side of Ohio
basketcase Online content
basketcase  Online Content
east side of Ohio
1981 Dodge D150 360 auto
Re: 275's all around on a B-body ? [Re: AlexP] #80381
06/28/08 02:42 AM
06/28/08 02:42 AM
17"/9"/4.5 backspace 275/55/17in back and 245/45/17 up front with rear sway bar no rubbing at all but no room for bigger tire terry
Re: 275's all around on a B-body ? #80382
06/28/08 09:25 AM
06/28/08 09:25 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
a board member had '01-04 mustang 17x8 rims on his '69 RR using 3/4" thick bolt on spacers (makes for 5" effective backspace) all the way around and 255/50R17 BF goodrich KDWS's and they fit fine. I have the same setup on my 5th ave
2017 Grand Cherokee Overland
Re: 275's all around on a B-body ? [Re: patrick] #80383
06/28/08 10:40 AM
06/28/08 10:40 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Re: 275's all around on a B-body ? [Re: basketcase] #80384
06/29/08 03:57 AM
06/29/08 03:57 AM
united kingdom
Simonic Offline
Simonic  Offline
united kingdom
Keeping the Bee Buzzin'
