440 and 413 steel cranks #803307
09/16/10 07:35 PM
09/16/10 07:35 PM
Texas
70Runnerdude Offline OP
Texas
Is there a difference between a 440 steel crank and a 413 steel crank I have one of each in the garrage and they seem to be the same even the numbers on the crank. Not sure on this one ????
Thanks!
Re: 440 and 413 steel cranks [Re: 70Runnerdude] #803308
09/16/10 07:42 PM
09/16/10 07:42 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
You will hear a lot of yes they are different in balance but they have been interchanged for years with no hardships.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: 440 and 413 steel cranks [Re: 70Runnerdude] #803309
09/16/10 08:25 PM
09/16/10 08:25 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Depends on the year I guess , pics posted of early cranks had an extra chunk of metal on the rod throws. Balance will be different , not sure how much lighter a 413 piston is vs a 440 but there is a very large difference in bore size , .195 .
Re: 440 and 413 steel cranks [Re: JohnRR] #803310
09/16/10 08:57 PM
09/16/10 08:57 PM
Depends on the year I guess, pics posted of early cranks had an extra chunk of metal on the rod throws. Balance will be different , not sure how much lighter a 413 piston is vs a 440 but there is a very large difference in bore size , .195 .
4.32 - 4.1875 = .1325
Re: 440 and 413 steel cranks #803311
09/16/10 09:17 PM
09/16/10 09:17 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Early 413 cranks had an extended flange with 8 holes (looks allot like a Hemi crank). The extended flange was engineered to work with cast iron automatics which used no flex plate, the crank bolted directly to the converter. Later 413 cranks (easy to ID because they have 6 bolt holes in the flange) were basically identical to a 440 crank.
Re: 440 and 413 steel cranks [Re: ScottSmith_Harms] #803312
09/17/10 09:00 AM
09/17/10 09:00 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Early 413 cranks had...
I never knew that.
Another gem from Scott to add to my BB memory banks.
Re: 440 and 413 steel cranks #803313
09/17/10 09:39 AM
09/17/10 09:39 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I thought the bore size was 4.125
Re: 440 and 413 steel cranks [Re: JohnRR] #803314
09/17/10 10:34 AM
09/17/10 10:34 AM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
Re: 440 and 413 steel cranks [Re: Commando1] #803315
09/17/10 11:14 AM
09/17/10 11:14 AM
I never knew that.
Actually, ALL pre-62 Mopar V-8 cranks - big and small block; hemi, poly and wedge - had extended, 8-bolt crank flanges that the torque converter bolted directly to, w/o a flex plate.
Here's a pre-62 318 poly crank with extended 8-bolt flange
Re: 440 and 413 steel cranks #803316
09/17/10 11:21 AM
09/17/10 11:21 AM
Here's a six-bolt regular-flange 413 forged crank next to a 440 forged crank. I have no idea if the balance is different, but you will notice that every rod throw on the 413 crank (on the left) has a tab on it; the 440 crank has none.
Re: 440 and 413 steel cranks #803317
09/17/10 11:23 AM
09/17/10 11:23 AM
Upper Midwest
Upper Midwest
These are the ones that I referred to when I stated that countless of these were interchanged on 440's with no ill effects.
