440 and 413 steel cranks
#803307
09/16/10 07:35 PM
09/16/10 07:35 PM
Posts: 398 Texas
70Runnerdude
Texas
Is there a difference between a 440 steel crank and a 413 steel crank I have one of each in the garrage and they seem to be the same even the numbers on the crank. Not sure on this one ???? Thanks! Dave
Re: 440 and 413 steel cranks
[Re: JohnRR]
#803310
09/16/10 08:57 PM
09/16/10 08:57 PM
Depends on the year I guess, pics posted of early cranks had an extra chunk of metal on the rod throws. Balance will be different , not sure how much lighter a 413 piston is vs a 440 but there is a very large difference in bore size , .195 .
4.32 - 4.1875 = .1325
#803313
09/17/10 09:39 AM
09/17/10 09:39 AM
Posts: 75,047 U.S.S.A.
JohnRR
U.S.S.A.
I thought the bore size was 4.125
#803316
09/17/10 11:21 AM
09/17/10 11:21 AM
Here's a six-bolt regular-flange 413 forged crank next to a 440 forged crank. I have no idea if the balance is different, but you will notice that every rod throw on the 413 crank (on the left) has a tab on it; the 440 crank has none.
#803317
09/17/10 11:23 AM
09/17/10 11:23 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Later 413 cranks (easy to ID because they have 6 bolt holes in the flange) were basically identical to a 440 crank.
These are the ones that I referred to when I stated that countless of these were interchanged on 440's with no ill effects.
