Holley Carb Question #80264
06/26/08 09:00 PM
06/26/08 09:00 PM
Witness Protection Program
Kudakidd Offline OP
Kudakidd  Offline OP
Are power valves used on the secondary side of Holleys? A friend has a 750 vacuum secondary with a metering block. Although there was one in it, I can't find any tech info which lists PV's in the secondary side. What's the story?
Re: Holley Carb Question [Re: Kudakidd] #80265
06/26/08 09:05 PM
06/26/08 09:05 PM
Kirkland, Washington
Pacnorthcuda Offline
sounds like someone replaced the metering PLATE with the block (its often done)and installed the PV.
Re: Holley Carb Question [Re: Kudakidd] #80266
06/26/08 09:45 PM
06/26/08 09:45 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
The original 3310 ( -1 suffix, I think, 780 cfm) came with primary and secondary metering blocks, with 8.5 and 10.5 valves respectively. This was also the BB Chevy configuration.
Re: Holley Carb Question [Re: Kudakidd] #80267
06/26/08 09:54 PM
06/26/08 09:54 PM
Andrewh Online content
Andrewh  Online Content
the vacuum secondary ones, old style anyway did not have pv in the secondary side.
you usually find a plate there with a recess that isn't cut all the way through that looks like a pv could go there, but there was not.
Re: Holley Carb Question [Re: Leigh] #80268
06/26/08 10:07 PM
06/26/08 10:07 PM
Kudakidd Offline OP
Kudakidd  Offline OP
Thanks Leigh, this is exactly what I was hoping to find out. The carb is a 780cfm on a friends '71 Z-28 ( 350ci). Whether or not the carb came thru with a metering block or plate, didn't matter. I just needed to know IF and what SIZE secondary PV should be used.
Re: Holley Carb Question [Re: Pacnorthcuda] #80269
06/26/08 10:09 PM
06/26/08 10:09 PM
i gotta mark this day down in the calender, becouse
Re: Holley Carb Question [Re: Leigh] #80270
06/27/08 06:32 AM
06/27/08 06:32 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Leigh is correct. I just checked the list and it did note that the 3310-1 is a 780cfm unit with 72/76 jets and a 025 nozzle. It showed under "PV" to see notes #12 & 13. #12 shows a 8.5 secondary pv and #13 note shows a 10.5 primary pv. I found this info on page #1 of the Holley part number listings (which I can't get attached to this response).
Edit:
I made a two page PDF that shows the info including notes #12 & #13.
4514858-Holley3310.pdf (268 downloads)
Re: Holley Carb Question [Re: YO7_A66] #80271
06/27/08 09:27 AM
06/27/08 09:27 AM
Kudakidd Offline OP
Kudakidd  Offline OP
Edit:
Dave , Thanks for the PDF. Now my friend can file it for future reference.
Re: Holley Carb Question #80272
06/27/08 04:26 PM
06/27/08 04:26 PM
Then my statement must clearly be incorrect.
