Re: Holley Carb Question
[Re: Leigh]
#80268
06/26/08 10:07 PM
06/26/08 10:07 PM
Posts: 7,861 Witness Protection Program
Kudakidd
The original 3310 ( -1 suffix, I think, 780 cfm) came with primary and secondary metering blocks, with 8.5 and 10.5 valves respectively. This was also the BB Chevy configuration.
Thanks Leigh, this is exactly what I was hoping to find out. The carb is a 780cfm on a friends '71 Z-28 ( 350ci). Whether or not the carb came thru with a metering block or plate, didn't matter. I just needed to know IF and what SIZE secondary PV should be used.
[Re: Pacnorthcuda]
#80269
06/26/08 10:09 PM
06/26/08 10:09 PM
sounds like someone replaced the metering PLATE with the block (its often done)and installed the PV.
i gotta mark this day down in the calender, becouse
[Re: Leigh]
#80270
06/27/08 06:32 AM
06/27/08 06:32 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
Leigh is correct. I just checked the list and it did note that the 3310-1 is a 780cfm unit with 72/76 jets and a 025 nozzle. It showed under "PV" to see notes #12 & 13. #12 shows a 8.5 secondary pv and #13 note shows a 10.5 primary pv. I found this info on page #1 of the Holley part number listings (which I can't get attached to this response).
Edit: I made a two page PDF that shows the info including notes #12 & #13.
[Re: YO7_A66]
#80271
06/27/08 09:27 AM
06/27/08 09:27 AM
Kudakidd
Dave , Thanks for the PDF. Now my friend can file it for future reference.
#80272
06/27/08 04:26 PM
06/27/08 04:26 PM
Posts: 21,835 Kirkland, Washington
Pacnorthcuda
Then my statement must clearly be incorrect.
