how do i tell if a sure grip is any good? #80239
06/26/08 07:05 PM
06/26/08 07:05 PM
Laveen, Arizona
GTSDart340 Offline OP
Laveen, Arizona
ok, so i have a 3.55 gear set for a 9 1/4. i believe it is a clutch type. how do i tell if it is any good, or if it needs to be rebuilt? i would rather not just install it to find out. thanks for the help!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: how do i tell if a sure grip is any good? [Re: GTSDart340] #80240
06/26/08 10:07 PM
06/26/08 10:07 PM
well considering you don't wanna check it the HARD way, i'll tell yah the EASY way. Put a tire iron, interlock
it with the wheel studs on one side of the axle. on the otherside, put a lug nut on one of the studs, put a torque
wrench on it. if it holds to anything over 70 ft-lbs.. your golden. BTW.. you most likely have the "cone" style grip.
PS i say 70ft-lbs cause you may break the stud.
Re: how do i tell if a sure grip is any good? #80241
06/27/08 12:34 AM
06/27/08 12:34 AM
Laveen, Arizona
Laveen, Arizona
...its not installed in the truck. is there a way to check it before i install it?
Re: how do i tell if a sure grip is any good? [Re: GTSDart340] #80242
06/27/08 12:50 AM
06/27/08 12:50 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Take it apart and make sure the cones are not bottomed out inside the carrier.
Re: how do i tell if a sure grip is any good? [Re: DoctorDiff] #80243
06/27/08 10:31 AM
06/27/08 10:31 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Not to highjack here but how can I tell if the cones are bottomed out? Do you have any pics? Mike
