how do i tell if a sure grip is any good?
#80239
06/26/08 07:05 PM
06/26/08 07:05 PM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
ok, so i have a 3.55 gear set for a 9 1/4. i believe it is a clutch type. how do i tell if it is any good, or if it needs to be rebuilt? i would rather not just install it to find out. thanks for the help!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: how do i tell if a sure grip is any good?
[Re: GTSDart340]
#80240
06/26/08 10:07 PM
06/26/08 10:07 PM
well considering you don't wanna check it the HARD way, i'll tell yah the EASY way. Put a tire iron, interlock it with the wheel studs on one side of the axle. on the otherside, put a lug nut on one of the studs, put a torque wrench on it. if it holds to anything over 70 ft-lbs.. your golden. BTW.. you most likely have the "cone" style grip.
PS i say 70ft-lbs cause you may break the stud.
#80241
06/27/08 12:34 AM
06/27/08 12:34 AM
GTSDart340
Laveen, Arizona
...its not installed in the truck. is there a way to check it before i install it?
