Re: Those ugly body trim clip holes
[Re: Mickey Mikie]
#80163
06/26/08 04:28 PM
06/26/08 04:28 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
One of the common ways to fill the holes is to make a backup out of flattened copper tubing; hold the copper over the backside of the hole and fill the holes with a mig welder.
[Re: Mickey Mikie]
#80165
06/26/08 05:42 PM
06/26/08 05:42 PM
Posts: 666 Anywhere the British Secret Se...
Moonraker
What's the best process for filling these holes? I suppose many have just filled with plastic filler, but I want to do something more permanent.
I've been thinking about placing large-headed steel nails through the hole from the inside and brazing them in place and using a cutoff wheel to remove the nail shank.
Is there a slicker way?
You could braze them but you might warp the bejesus out of the panel. The best way is to mig or tig weld them shut for a permanent solution. If you do a little at a time and move around to different holes you wont warp the body panels. Depending on the diameter of the holes I have also used a nail gun for pulling dents to "weld" the pulling nails in place over the hole and simply grinding it down flush with the panel, seen lots of guys do this to works great.
[Re: OzHemi]
#80167
06/26/08 06:04 PM
06/26/08 06:04 PM
Posts: 4,744 Florida
BDW
I bought one of THESE from Eastwood to fill some holes in the engine bay, has worked great so far
How exactly does this work? What do you do?
[Re: Neil]
#80169
06/26/08 07:25 PM
06/26/08 07:25 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Never seen one before either.
Let me guess; The magnetic base sticks to the sheetmetal and you can adjust the angle and tension of the copper end with the knob above the magnet. This tool creates a hands free way of filling holes.
Ding Ding Ding...give that man a prize (for reading the link I posted )
That is it..and the magnet is surprisingly strong for it's size
