Front shock grommets, where to get the RIGHT ones?? #800530
09/13/10 09:17 PM
09/13/10 09:17 PM
GA
roadrunninMark Offline OP
GA
69 RR, replacing front shocks, the grommets supplied that "fit" the top mount are ridiculously sloppy and sandwich in place. Does anyone carry the original rubber grommets that push through the bottom side and correctly and completely isolate the hole for the shaft of the shock?
Mark
Re: Front shock grommets, where to get the RIGHT ones?? [Re: roadrunninMark] #800531
09/13/10 10:18 PM
09/13/10 10:18 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
these ?
Re: Front shock grommets, where to get the RIGHT ones?? [Re: gtx6970] #800532
09/14/10 08:53 AM
09/14/10 08:53 AM
GA
GA
Yes, those Ill send you a PM
Mark
Re: Front shock grommets, where to get the RIGHT ones?? [Re: gtx6970] #800533
09/14/10 01:02 PM
09/14/10 01:02 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
these ?
Will they stand up to the heat of a turbo? I burn out the passenger side in a few hours of run time.
- Stu Harmon
Re: Front shock grommets, where to get the RIGHT ones?? [Re: feets] #800534
09/14/10 02:38 PM
09/14/10 02:38 PM
tboomer Offline
tboomer  Offline
I think I have a pair of NOS ones with the top and bottom plates with the nuts...
Re: Front shock grommets, where to get the RIGHT ones?? [Re: roadrunninMark] #800535
09/14/10 03:05 PM
09/14/10 03:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Mark
They push thru from the top not the bottom .
Re: Front shock grommets, where to get the RIGHT ones?? [Re: JohnRR] #800536
09/14/10 03:20 PM
09/14/10 03:20 PM
tboomer Offline
tboomer  Offline
Re: Front shock grommets, where to get the RIGHT ones?? [Re: feets] #800537
09/14/10 03:42 PM
09/14/10 03:42 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Sorry, I can't answer that one
The correct washers
Re: Front shock grommets, where to get the RIGHT ones?? [Re: gtx6970] #800538
09/14/10 03:56 PM
09/14/10 03:56 PM
tboomer Offline
tboomer  Offline
Dug mine out,Bill...The have a dab of white paint on top of each one and are marked "TOP"...Can't put those in wrong!! looks like 2206923 for a number...
