Re: Front shock grommets, where to get the RIGHT ones??
[Re: gtx6970]
#800532
09/14/10 08:53 AM
09/14/10 08:53 AM
Posts: 2,943 GA
roadrunninMark
GA
Yes, those Ill send you a PM Mark
[Re: roadrunninMark]
#800535
09/14/10 03:05 PM
09/14/10 03:05 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
69 RR, replacing front shocks, the grommets supplied that "fit" the top mount are ridiculously sloppy and sandwich in place. Does anyone carry the original rubber grommets that push through the bottom side and correctly and completely isolate the hole for the shaft of the shock?
Mark
They push thru from the top not the bottom .
[Re: feets]
#800537
09/14/10 03:42 PM
09/14/10 03:42 PM
Posts: 21,442 It's a dry heat
gtx6970
It's a dry heat
Will they stand up to the heat of a turbo? I burn out the passenger side in a few hours of run time.
Sorry, I can't answer that one
The correct washers
