Removing front wheel cylinders on 1967 Coronet
#80037
06/26/08 12:19 PM
06/26/08 12:19 PM
Posts: 1,307 BC, Canada
Black_Bee
BC, Canada
Hey Guys! What is the procedure for removing the front wheel cylinders on a '67 B-Body? It appears that the bolts holding the wheel cylinder on are not accessible without removing the backing plate from the suspension. I can get at one of the bolts, but the one right beside the brake line doesnt appear to be accessible. Is there a trick to this that Im not seeing? I have the FSM but it doesnt show anything. Thanks guys!
Paul '69 Super Bee 383 EFI Turbo
Re: Removing front wheel cylinders on 1967 Coronet
[Re: Black_Bee]
#80038
06/26/08 05:25 PM
06/26/08 05:25 PM
Posts: 9,312 SoCal
68HemiB
SoCal
I don't have a '67 in front of me to look at, but that doesn't sound right (to have to remove the backing plate).
The "inaccessible" bolt by the brake line - are you married to the idea of removing it with a socket, and haven't tried a box-end wrench on it? (Probably unlikely, but I thought I'd ask anyway.) Also, if it's just a matter of having enough clearance to back the bolt ALL the way out, just remove the other bolt first, and let the WC pull away from the backing plate as you turn the remaining bolt, effectively leaving the bolt head where it is.
If none of this applies, then try removing the brake line. You were going to have to separate it from the WC anyway, so all this adds to the project is the need to remove the other end of the rubber line (so you can spin it out of the WC).
Down to just a blue car now.
[Re: 68HemiB]
#80039
06/26/08 07:16 PM
06/26/08 07:16 PM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
I'll try this again, I pulled the front end off my 66' and it appears to be original as far as I can tell anyway.
The one WC bolt is only accesible with a 1/2" open end wrench, after the hose is removed. I tried several other tools to get at them but there's just not enough room to do it. The hoses came off with minimum effort.
I pulled the whole spindle/drum off as a unit in favor of discs after the front is rebuilt, and I have them lying on the ground wiht a cut chunk of hose still theaded into the WC and it's not even possible to get at the mount bolt on the hose side with the hose in place, and there's no room for a socket between the knuckle and the backing plate regardless, it's not even an option.
HTH's
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: R70RUNNER]
#80040
06/26/08 10:21 PM
06/26/08 10:21 PM
RapidRobert
You definitely do not ahve to R&R the backing plate to get at the (2)wheel cyl bolts on the backside. you might try a 3/8"(IIRC) offset box end wrench.
[Re: RapidRobert]
#80041
06/27/08 12:10 AM
06/27/08 12:10 AM
Posts: 7,833 east side of Ohio
basketcase
east side of Ohio
never did a Coronet, but the '67 Charger I had was no harder than my '68 or '69
1981 Dodge D150 360 auto
[Re: Black_Bee]
#80042
06/27/08 12:29 AM
06/27/08 12:29 AM
Black_Bee
BC, Canada
Hey Guys! OK, thanks a bunch... I just have to remember not to give up so easily! I will remove the hose... its not like this one is different from all the other ones that you guys have worked on! I swear my '69 Bee was easy as pie though. Paul
