340 motor mounts R the same as 318-correct? #80010
06/26/08 11:20 AM
06/26/08 11:20 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
I have a late mod K member, 73 era going into my 67 Dart. I am going out today and try and find a set of motor mounts locally at the parts houses. I am assuming that 340 mounts are the same as 318 mounts??
Re: 3240 motor mounts R the same as 318-correct? [Re: RUMBLON] #80011
06/26/08 11:25 AM
06/26/08 11:25 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
no not the same on the left side. 340-360 the same
Re: 3240 motor mounts R the same as 318-correct? [Re: mopars4ever] #80012
06/26/08 11:46 AM
06/26/08 11:46 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
ok, thats probably better tey, do ya think most local auto parts places will carry them in stock? Or am I wasting my time and need to order them?
Re: 3240 motor mounts R the same as 318-correct? [Re: RUMBLON] #80013
06/26/08 01:08 PM
06/26/08 01:08 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
The right motor mount bracket is the same between 318, 340, and 360. The left bracket is what is different. The 318 has a different bracket on the left side then the 340-360 does. The motor mounts (the rubber parts) are the same for all three engines.
Re: 3240 motor mounts R the same as 318-correct? [Re: 69Cuda340S] #80014
06/26/08 01:24 PM
06/26/08 01:24 PM
md
md
NAPA carries them.
Motor Mount - Front
Right Complete Unit BK
6021516
$22.99
Motor Mount - Front
Left Complete Unit BK
6021556
$20.99
Re: 3240 motor mounts R the same as 318-correct? [Re: mopars4ever] #80015
06/26/08 01:38 PM
06/26/08 01:38 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
For the drivers side engine bracket I think some guys here have just made up the difference in width between 340/318 brackets with a few washers
Re: 3240 motor mounts R the same as 318-correct? [Re: UCUDANT] #80016
06/26/08 02:11 PM
06/26/08 02:11 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Correct, the 318 bracket can be made to work on a 340/360 engine by using washers as spacers.
Re: 3240 motor mounts R the same as 318-correct? [Re: 69Cuda340S] #80017
06/27/08 12:12 AM
06/27/08 12:12 AM
md
md
I believe he doesn`t have any mounts so why not buy the correct ones. Mike
