Re: Flasher location
[Re: dtedler]
#799994
09/13/10 10:18 AM
09/13/10 10:18 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
You may have to stand on your head to finds it under the dash.Do the signal lights work and just the flasher that don't or is it both the signals and flashers? If one works but not the other you likely have a bad flasher but if neither work you could have 2 bad flashers or other problems. It won't be bulbs if one works and not the other. Signals and 4 way use separate flashers.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: broncobra]
#799997
09/13/10 12:16 PM
09/13/10 12:16 PM
MoparforLife
Upper Midwest
Should be pug in in the fuse block. Should be able to open the door, look in with a flashlight and locate it easily. Should be easily accessible. See that the Tigers are in the top 25! Good for the Big 12!
Some models did and some didn't. There is also like said above 2 flashers - one for turn signals and 1 for 4 way.
[Re: Runnin74]
#799999
09/16/10 12:41 PM
09/16/10 12:41 PM
Posts: 263 Switzerland, Europe
Swiss_Robert
Switzerland, Europe
Flasher has a holding clip on the right side of the ashtray-"chamber". Similar to the one for the hazard-flasher at the pedal-bracket.
After all these years having a 440 I realized that this means having an attitude... and a budget.
[Re: dtedler]
#800000
09/16/10 05:58 PM
09/16/10 05:58 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
Everything worked fine until he installed the LED bulbs. He got a no-load solid state flasher to replace the stock bi-metal unit. I'm gonna make him stand on his head this time.....What a great learning experience, plus his arms are longer! I'll do my best to provide the needed words of encouragement. This has been a great experience for us.
If he's got LEDs in everything, it still might not work. I have LEDs in everything - rear, front, side-markers, and dash - AND an electronic ("no-load") flasher. Couldn't make it work without having at least one incandescent bulb on the outside on each side of the car. Didn't like the way the incandescent looked, so kept the LEDs. Finally had to add a 5W (IIRC) load resistor to each side on the front turn signal wire for it all to work.
