for doc fiberglass #799648
09/12/10 11:08 PM
09/12/10 11:08 PM
california
moparmanof85 Offline OP
california
how many ft-lbs of torque does the 413 industrial put out?... stock w/ 4bbl
Re: for doc fiberglass [Re: moparmanof85] #799649
09/12/10 11:52 PM
09/12/10 11:52 PM
california
california
doc?
Re: for doc fiberglass [Re: moparmanof85] #799650
09/13/10 12:57 AM
09/13/10 12:57 AM
S.E. Conn
Hoof Hearted Offline
S.E. Conn
Is Doc's pm box full?
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: for doc fiberglass [Re: moparmanof85] #799651
09/13/10 01:12 AM
09/13/10 01:12 AM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
Hey ... ...
LOTS of numbers have been thrown around here and there ..... I have seen #'s as low as 325 and as high as 445. SAME engine specs(compression, cam, heads, exhaust - ETC ...go figure ... ... ...
It IS a very weak engine .... BUT also very durable ! GET some decent-compression in it(from 6.7 to 9 to 1), some tweeked cyl heads(swirl-ported and massaged combustion chambers), along with a 2010 cam UPgrade(Crane or Comp) and better fuel delivery(a TQ with either a Streetmaster or SP2P intake) ..... and you have a helleva' motor for what is WAS designed for .... an RV/truck "grunt" engine.
And JUST THIS PROJECT is on one of my engine stands.
Re: for doc fiberglass [Re: BeEtLeJuIcE !] #799652
09/13/10 01:15 AM
09/13/10 01:15 AM
california
california
thanks doc. thats what i need. do you have a better cam part number for a torky puller?
Re: for doc fiberglass [Re: moparmanof85] #799653
09/13/10 01:21 AM
09/13/10 01:21 AM
Florida STAYcation
Florida STAYcation
The cam is a "problem" area. I am still collating.
Some of the 2010 "tech" (like the current Chebby stuff) is some radical stuff.
VERY short duration ... but HUUUGE lift. So what is needed is a roller ? ... and then how about valve springs ??
I don't know ...
Re: for doc fiberglass [Re: BeEtLeJuIcE !] #799654
09/13/10 02:02 AM
09/13/10 02:02 AM
california
california
keep me posted
Re: for doc fiberglass [Re: moparmanof85] #799655
09/13/10 02:47 AM
09/13/10 02:47 AM
Florida STAYcation
Florida STAYcation
What are you going to be doing with it ? .. how deep do you want to go into it?
