Re: Neon Front End Issue
[Re: Plymouth273]
#798644
09/11/10 02:50 PM
09/11/10 02:50 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
The lc bushings are known for going bad.The big round rear one.It rips out of the steel part.Usually you can see the A arm sitting on the frame.They arent that hard to replace unless the captured nut in the frame brakes loose from the weld.Rocky
Chrysler Firepower
[Re: therocks]
#798646
09/11/10 06:57 PM
09/11/10 06:57 PM
Posts: 4,628 Columbus, Ohio
wheelsup68dart
Columbus, Ohio
Agree 100%
[Re: wheelsup68dart]
#798647
09/13/10 01:23 PM
09/13/10 01:23 PM
Posts: 2,431 USA
SSAAHemiFan
USA
Wifes car is on it's 3rd set at 77,000 miles. First time factory arms replaced under warranty, second time I just replaced all bushings with Moog, this last time I went with aftermarket arms. ALso check for broken or blown out motor mount.
[Re: ahy]
#798649
09/14/10 08:45 AM
09/14/10 08:45 AM
therocks
Niles , Ohio
The bushings also have a notch that has to go in one way.I believe it goes toward the front.Its been a while since I did a set.Rocky
Chrysler Firepower
